Results 1 to 3 of 3
Thread: Cant tag a slab from underneath
    Senior Member
    December 16, 2010
    863
    01:31 PM
    I have made a slab tag very simple, used a generic tag family and categorised it to slab and chose structural thickness.
    My slabs are only structural no multilayer.
    My structural views are done from underneath showing elements impacting overhead in hidden line.
    It is a structural plan view with the direction changed to upwards instead of looking downwards.
    I can not place my tag on the slab in the view....if I go to an architectural style plan view I can place the tag from "above" the slab, but when I am looking from below can not place the tag.....
    Anyone have a workaround for this? I want it to be a smart tag, not just a symbol that I can modify the text in.
    Moderator cellophane's Avatar
    August 9, 2011
    Louisville, KY
    6,164
    11:31 PM
    is your view hidden line or wireframe? does your view range include the slab(s)?
    Senior Member
    December 16, 2010
    863
    01:31 PM
    hidden, and yes slabs are included
    And actually its resolved itself
    When I loaded the tag in it wasnt letting me place it, I made some modifications to the contents, included the elevations at top/bottom in the tag and now it works, go figure...
  1. Callout heads show material pattern underneath
    By PhylVance in forum Architecture and General Revit Questions
    Last Post: January 8th, 2019, 03:49 PM
  2. Slab falls show the ‘hidden’ line in slab soffit
    By jh75 in forum Architecture and General Revit Questions
    Last Post: April 19th, 2017, 11:24 AM
  3. how to create a wall underneath a staircase
    By starmandell in forum Architecture and General Revit Questions
    Last Post: November 5th, 2015, 06:09 PM
  4. Objects appearing underneath Floor Plan
    By JPREng in forum Architecture and General Revit Questions
    Last Post: November 5th, 2014, 05:13 AM
  5. Family hides things underneath it
    By marianopa in forum Architecture - Family Creation
    Last Post: November 3rd, 2014, 10:10 AM
