Results 1 to 3 of 3
Thread: revit elevation lines shows items behind created elevation view
    July 16, 2018
    1
    09:06 PM
    Lightbulb revit elevation lines shows items behind created elevation view
    i am having a problem with my revit elevation lines. when create an elevation it keeps showing whats behind the elevation line, which seems pretty odd.
    Moderator DaveP's Avatar
    January 10, 2011
    St Paul, MN
    2,984
    04:06 PM
    A screen shot would be helpful to explain your problem better.
    Mr. Revit OpEd
    2,882
    02:06 PM
    Sounds like wireframe when you expect hidden line display? If you are using hidden line and it still looks like it is wireframe...do you have any DWG files linked/imported? When a DWG has very large extents (usually a warning accompanies the linking/importing process) one of the symptoms of that DWG being visible is what you describe. Turn off the DWG in the view, that should change how it looks.
  1. Copying Symbolic Lines From a Plan View to an Elevation View??
    By Legoboy in forum Architecture and General Revit Questions
    Last Post: December 23rd, 2015, 04:09 PM
  2. How Can I Hide Slab elevation Lines In Elevation ?
    By YahyaM. in forum Architecture and General Revit Questions
    Last Post: March 19th, 2014, 08:28 AM
  3. elevation marker related to specific elevation view
    By Ning Zhou in forum Third party Add-Ins, API and R&D
    Last Post: February 20th, 2013, 06:24 AM
  4. Interior Elevation Markers - all four view created on placement
    By Pashcal in forum Architecture and General Revit Questions
    Last Post: June 7th, 2012, 02:35 PM
  5. Show the hidden lines in Elevation view
    By Clara2011 in forum Structure - General Questions
    Last Post: November 29th, 2011, 06:36 PM
