Results 1 to 2 of 2
Thread: Callout heads show material pattern underneath
  1.    #1
    December 19, 2018
    4
    02:39 AM
    I'm about to rip my hair out! Our callout tags on our drawings show the material hatching of whatever is underneath them and this is making it hard to read what the tag actually says. I've edited the callout head family. I've made the labels opaque, I added a masking region, and I even added a white solid filled region behind the whole thing and no matter what I do nothing changes. I even created a new callout head label family with all of this. Its loaded into the project and I can SEE it in the window for selecting callout heads but when I select it, it looks the same as all the others! Please help, I think I'm going crazy
  2.    #2
    December 19, 2018
    4
    02:39 AM
    So I figured out what was wrong. I had a coworker look at this and apparently i was selecting a Callout head when I was meant to be selecting a section head. He loaded an opaque section head instead and my drawing look exactly how i want them.
  1. Wall material display - Fill vs Material pattern
    By ncowherd in forum Architecture and General Revit Questions
    Last Post: August 11th, 2015, 03:39 PM
  2. Section/callout heads are plotting half-tone.
    By volney68 in forum Architecture and General Revit Questions
    Last Post: September 27th, 2014, 02:10 PM
  3. Level Heads, Sections, and Callout Color
    Last Post: July 31st, 2013, 02:06 PM
  4. Section / Callout Heads are Orange
    By Chadwick17 in forum Architecture and General Revit Questions
    Last Post: March 9th, 2013, 06:22 PM
  5. Shared Parameters for Elevation / Section / Callout Heads ?
    Last Post: June 8th, 2011, 06:48 PM
