Results 1 to 10 of 10
Like Tree1Likes
  • 1 Post By DaveP
Thread: lisp
    Lurker
    January 8, 2019
    1
    01:52 PM
    lisp
    Does REVIT have any language utilities like LISP?
    June 21, 2012
    Tours, France
    894
    02:52 PM
    Quote Originally Posted by meihome View Post
    Well LISP NO, that is more for AutoCAD, in Revit you can work with DYNAMO which allows you to create automations for several tasks!
    Member mjajansen's Avatar
    December 26, 2011
    The Netherlands
    168
    02:52 PM
    There is also the option to use PyRevit with Python or just use the API directly with C#
    June 21, 2012
    Tours, France
    894
    02:52 PM
    Quote Originally Posted by mjajansen View Post
    There is also the option to use .... Python or just use the API directly with C#
    Yes, but on the other hand you need to have some programming knowledge to do so!!
    Coeur d Alene, ID
    4,629
    06:52 AM
    "I am NOT a Revit tutor!"
    Dave Jones's Avatar
    4,479
    06:52 AM
    not any different with LISP or VLISP (lost in stupid parentheses)
    Moderator DaveP's Avatar
    January 10, 2011
    St Paul, MN
    2,879
    08:52 AM
    I love writing VB Macros in Excel!
    Now, if Revit only had a Macro Recorder so I could learn how to write macros in Revit....
    Coeur d Alene, ID
    4,629
    06:52 AM
    Isn't that what a Journal file is?
    January 10, 2011
    St Paul, MN
    2,879
    08:52 AM
    Nope.
    The Journal file is just a log of everything Revit did & the commands (icons) that you picked. It's basically a debugging tool.
    ' E 03-Jan-2019 15:51:16.258; 0:<
    Jrn.AppButtonEvent 0 , "Application Menu is closing"
    'E 03-Jan-2019 15:51:16.370; 0:<
    Jrn.MouseMove 0 , 236 , 112
    Jrn.Command "Ribbon" , " , ID_REVIT_SAVE_AS_FAMILY"
    The Excel Macro Recorder writes the VB code for you.
    that's how I learned, not only Excel Macros, but pretty much how to code in VB.
    Turn on the Recorder, do what you want in Excel, turn off the Recorder & just like magic, you have executable VB code written
    Sub Macro3()
    ' Macro3 Macro
    Range("A127:O127").Select
    Application.CutCopyMode = False
    ActiveCell.FormulaR1C1 = "=SUM(R[-13]C[14],R[-1]C[14])"
    End Sub
    cellophane likes this.
    Moderator cellophane's Avatar
    August 9, 2011
    Louisville, KY
    6,050
    09:52 AM
    Nope.
    Holy **** that's awesome!! I didn't know it would do that!
