Results 1 to 3 of 3
Thread: Revit wall termination in plan
    February 16, 2016
    102
    11:00 AM
    I do not wish to appear stupid but can anyone help me out here? The problem is how do I ensure a wall ending aligned with other elements? As you can see from the attached image it does not.
    It is true that the wall joins tool gives you many options for ending a wall. However this is a single wall so I can’t use that.
    Is wrapping the right approach?
    Using family editor to create a particular profile, presumably with a void object might be the answer. Surely there must be an easier way? I have tried using align tool with no success.
    Thank you
    Attached Thumbnails Attached Thumbnails Revit wall termination in plan-wall-junction-4-1-19.jpg
    Forum Addict Robin Deurloo's Avatar
    July 7, 2011
    Rotterdam, Holland
    1,058
    12:00 PM
    When I have one of those I usually make a generic model with a void and cut that from the wall.
    It would be nice if we could do something like the endcap in ACA.
    June 7, 2016
    38
    03:00 AM
    Quote Originally Posted by Ecotech Kid View Post
    Thank you
    Make a very thin wall (1/32" or 5/8" for the thickness of gypsum board, etc.) and place it aligned to the angled edge. Then trim this wall to your original wall, which will cause it to clean up and give you an angled end. The new (thin) wall does not have to be very long. It can in fact be as long as the original wall is wide, which will make it invisible for all intents and purposes.
  1. Handrail termination not shown in plan view
    By gpktm in forum Architecture and General Revit Questions
    Last Post: September 1st, 2017, 02:09 AM
  2. Handrail Termination
    By rkitect in forum Architecture and General Revit Questions
    Last Post: January 27th, 2015, 03:09 PM
  3. Upgrade RFA causes termination
    By gwnelson in forum Architecture and General Revit Questions
    Last Post: May 2nd, 2013, 07:51 PM
  4. Wall Tags for wall panels - Display in plan and elevation
    By JasonWallis in forum Architecture and General Revit Questions
    Last Post: January 30th, 2012, 07:45 PM
