Results 1 to 6 of 6
Thread: level/grid 2d/3d
    Member philsogood's Avatar
    June 30, 2016
    Lyon - France
    137
    06:37 AM
    level/grid 2d/3d
    hello everybody
    happy new year, lots of love and fun for 2019!! (and not only with revit!!)
    since a too long time, i'm asking what does 2d/3d means on grids and levels?? i don't know how to use it
    some time i can change to 2d to 3d (and then i can move end of grid/levels) but i realised that after this change i can't change to 2d to 3d...
    waiting for yours bright ideas for this issue!!
    thanks
    Phil
    June 21, 2012
    Tours, France
    937
    08:37 AM
    Hi phil and cheers for you too! 2D/3D on grids and levels means the the "Grid line" or the "level line" can be visible in 2D views like sections, elevations and so on, that means that if you want to see (or not) the grid lines you need to move the 2D grip to only see the modification in the view you are working on, if you move the 3D grip that means that you'll modifying the "grid line" or "level line" in all related views changing the way you see those in your specifics views, in other words those controls allow you to see and modify the grid lines in one view (2D) or in the model (3D) hope this is clear enough, regards
    Senior Member kamranmirza's Avatar
    January 12, 2011
    London, UK
    529
    07:37 AM
    . . . hope this is clear enough . . .
    Good visual explanation here too:
    https://knowledge.autodesk.com/suppo...2d%203d%20grid
    June 21, 2012
    Tours, France
    937
    08:37 AM
    Quote Originally Posted by kamranmirza View Post
    Good visual explanation here too..
    an image (video) talks more than a thousand words, anyway is more or less that I said!!
    Mr. Revit OpEd
    2,861
    11:37 PM
    I use Global (3D) and Local (2D) to help describe how they relate to grids and levels. 3D/2D don’t really relate well to them as intuitively as some seem to think.
    June 30, 2016
    Lyon - France
    137
    06:37 AM
    Thanks a lot
    I've got it... Need to do few test to assimilate it
    2d/3d it's really a bad name
    2019 is starting good
  1. Grid extents per level. Z axis issue.
    By elton williams in forum Architecture and General Revit Questions
    Last Post: September 8th, 2017, 11:06 PM
  2. Send Grid and Level lines to background
    By byk3bep in forum Architecture and General Revit Questions
    Last Post: November 10th, 2016, 07:14 PM
  3. Adjusting Grid and Level Lines Per View,...Please Help
    Last Post: June 13th, 2012, 09:15 PM
  4. Dragging Grid and Level Ends
    By dzatto in forum Tutorials, Tips & Tricks
    Last Post: April 11th, 2012, 07:52 PM
  5. Level and Grid Question
    By dbakerstl in forum Architecture and General Revit Questions
    Last Post: June 9th, 2011, 02:47 AM
Tags for this Thread
