Results 1 to 10 of 10
Like Tree2Likes
  • 1 Post By Bjorn_K
  • 1 Post By mjajansen
Thread: Wall sweeps / IFC export
    November 18, 2016
    93
    02:24 PM
    I'm exporting my revit model to .IFC and we have noticed that all wall sweeps are classed as "objects" within the IFC and not walls. Part of our BEP states that "objects" are not allowed within the IFC file I've tried changing the IFC export classes for a wall sweep via the IFC options but this hasnt worked. It seems as if it takes it's export class from the fact it is a profile rather than a wall sweep and there isnt any option to change the class of a profile (i presume as it is a 2d element as opposed to a 3d one).
    Is this something anyone else has come across before and if so does anyone know a workround or solution for this?
    Many thanks
    Member Bjorn_K's Avatar
    April 8, 2011
    Rotterdam, Netherlands
    325
    03:24 PM
    Build your own (Face-Based) Families for anything you use Wall Sweeps for. Because of the problem you've now encountered, Wall Sweeps are Do Not Use if the deliverable is an IFC file.
    Autodesk is aware of this, Angel confirmed it is on their to-do list when he was at the IFC day at Schiphol little while ago.
    robp likes this.
    November 18, 2016
    93
    02:24 PM
    Bjorn, thank you very much. I'm glad in one way that at least i now know im doing something fundamentally wrong. Hopefully this is something that will get a fix in due course as we use sweeps a lot for copings and brick detailing.
    I wonder if a face-based family will work on a curved wall??
    April 8, 2011
    325
    03:24 PM
    Quote Originally Posted by robp View Post
    Nope. Build something that has a radius parameter so it can curve along it's path.
    Member mjajansen's Avatar
    December 25, 2011
    The Netherlands
    197
    01:24 PM
    Just change your BEP and the problem is solved.
    Don't let the documentation make it harder for you, BIM is there to help, not to make it harder.
    edit: BEB needed to be BEP
    Senior Member kamranmirza's Avatar
    January 12, 2011
    London, UK
    538
    02:24 PM
    Quote Originally Posted by mjajansen View Post
    Just change your BEB and the problem is solved.
    What does beb mean? beb Definition. Meaning of beb. OnlineSlangDictionary.com
    November 18, 2016
    93
    02:24 PM
    Quote Originally Posted by Bjorn_K View Post
    thanks once again Bjorn
    November 18, 2016
    93
    02:24 PM
    Unfortunately we dont create the BEP. The client creates the BEP based on what they need to achieve / provide at the end of the job.
    January 12, 2011
    London, UK
    538
    02:24 PM
    Quote Originally Posted by kamranmirza View Post
    ??? What does beb mean?
    Ahhh . . . you meant BEP !
    Amazing what a difference one letter makes
    December 25, 2011
    The Netherlands
    197
    01:24 PM
    Changed it
    kamranmirza likes this.
  1. Breaking up wall sweeps without splitting the wall + resizing wall sweeps in plan
    By katewood1989 in forum Architecture and General Revit Questions
    Last Post: December 9th, 2016, 02:48 PM
  2. Wall Sweeps & Storefront
    Last Post: June 24th, 2015, 08:13 PM
  3. Wall Sweeps
    By Rmac in forum Architecture and General Revit Questions
    Last Post: January 13th, 2015, 12:38 PM
  4. Wall sweeps
    By steffe in forum Architecture and General Revit Questions
    Last Post: May 19th, 2014, 06:35 PM
  5. wall panel sweeps
    By elton williams in forum Architecture and General Revit Questions
    Last Post: October 27th, 2011, 06:18 PM
