Results 1 to 10 of 10
Like Tree1Likes
  • 1 Post By ocrender
Thread: The jagged lines in the edge of roof
    December 31, 2018
    7
    01:08 PM
    I created a “gable corrugated roofing” with “a right trapezoid foot print”.
    In a plan view, where the roof intersects an inclined line on the right side, its edge shows the jagged lines (see attachment).
    What cause it and how to fix this?
    Regards,
    Attached Thumbnails Attached Thumbnails The jagged lines in the edge of roof-screen-shot-1.png
    July 10, 2015
    Boise, Idaho
    681
    07:08 AM
    The ribs are center orientated. They terminate right where you told them to. But the width doesn't pay any attention to the angle.
    December 31, 2018
    7
    01:08 PM
    So, how to fix this jagged lines?
    Regards,
    Mr. Revit OpEd
    2,912
    06:08 AM
    What kind of element is it made of?
    December 31, 2018
    7
    01:08 PM
    The roof itself based on a “sloped glazing” with a “customised mullion profile”.
    Gold Coast
    2,626
    11:08 PM
    Quote Originally Posted by rimutaka18 View Post
    The top edge of your millions won't cut at that angle. You could try using custom curtain panels (instead of mullions) with the curve profile and build in a void to cut the sloped edges.
    Member mjajansen's Avatar
    December 25, 2011
    The Netherlands
    197
    01:08 PM
    You could also use a line based generic model with a 45 degree void on the end and then array them. A bit more work to adjust but it will be perfect and you know exactly how much length of panel you need to order.
    December 31, 2018
    7
    01:08 PM
    Thank for all suggestions provided.
    Regards
    June 7, 2016
    38
    05:08 AM
    Make a thin mullion profile (could be 1/32" wide with a transparent material) or use a profile that looks like the pour stop angle for the slab. When you have a mullion at the perimeter edge, the other mullions will trim at an angle.
    Dave Jones likes this.
  10.    #10
    June 21, 2019
    Tyler, Tx
    3
    01:08 PM
    Good Design Mr. rimutaka18 .. Home Looks Wonderful after roofing
  1. Foundation plan - Hidden lines/ Edge lines
    By Thasso00 in forum Architecture and General Revit Questions
    Last Post: October 31st, 2017, 01:34 PM
  2. Roof edge
    By shyock in forum Architecture and General Revit Questions
    Last Post: February 28th, 2017, 08:58 PM
  3. Filtering common floor edge lines
    By DavidLarson in forum Architecture and General Revit Questions
    Last Post: February 25th, 2017, 01:53 PM
  4. Build Edge Roof
    Last Post: January 18th, 2013, 09:58 PM
  5. Complex roof edge problem
    By Alfienoakes in forum Architecture and General Revit Questions
    Last Post: February 10th, 2011, 06:46 PM
