Results 1 to 6 of 6
Thread: Wall Wrapping in 3D - Visual Question
    December 4, 2018
    2
    11:16 PM
    Hi all,
    In the image below we are trying top wrap the material onto the window reveals. We have tried all wrapping options but nothing seems to work. Is it possible to wrap the material in 3D views?
    What may make this a little trickier is that we split the surface and applied a 'paint' material on this section.
    Thanks for any advice in advance.
    Attached Thumbnails Attached Thumbnails Wall Wrapping in 3D - Visual Question-wall-wrapping.jpg
    Member kamranmirza's Avatar
    January 12, 2011
    London, UK
    488
    11:16 PM
    Tick ‘wrap at inserts’ in the edit type properties dialog box for your wall.
    And most importantly make the material as the exterior surface of your wall and DON’T paint it on !
    December 4, 2018
    2
    11:16 PM
    Quote Originally Posted by kamranmirza View Post
    Thank you for the reply.
    I will try this. While I see your point about the painting I do not want to create 4 separate walls on one facade so thought splitting the surface was the best option. I will have to weigh up the pros and cons of each way.
    9,765
    05:16 PM
    Quote Originally Posted by RevitUser83 View Post
    Split face and paint sucks. Full stop.
    You definitely DO want to make four different walls.
    Aaron Maller
    Director
    Parallax Team, Inc.
    December 21, 2010
    C.LONDON
    4,339
    11:16 PM
    At the least.
    (itching to shout that screenshot screams "CURTAIN PANELS!")
    jmk
    jmk is offline
    Forum Addict jmk's Avatar
    December 31, 2012
    NM, USA
    1,383
    04:16 PM
    How are your windows made? If they are made with the storefront tool the wall won't wrap (even with wrap at inserts enabled)
  1. Wall wrapping at abutment (wall thickening)
    By ju_jigsaw in forum Architecture and General Revit Questions
    Last Post: September 25th, 2018, 05:38 PM
  2. Wall end wrapping diferentiated
    By juca64 in forum Architecture and General Revit Questions
    Last Post: November 28th, 2016, 04:44 PM
  3. Wrapping A Profile On A Wall
    By JD003 in forum Architecture and General Revit Questions
    Last Post: May 2nd, 2015, 05:14 PM
  4. Wall wrapping Question?
    By LAbraham in forum Architecture and General Revit Questions
    Last Post: June 24th, 2014, 06:58 PM
  5. Question regarding wrapping
    By andreakset in forum Architecture and General Revit Questions
    Last Post: November 17th, 2011, 10:57 PM
