Results 1 to 10 of 10
Like Tree1Likes
  • 1 Post By GMcDowellJr
Thread: Inner loops of a footprint sketch may not have slope-defining lines.
    August 14, 2018
    8
    07:35 PM
    Hello,
    I'm trying to create a simple square roof for a building with an interior courtyard, and I am getting this error message: "Inner loops of a footprint sketch may not have slope-defining lines."
    After this I tried to do this by cutting a slice from the roof (see picture below), but this has created a roof where the valley isn't in the right place. FYI The roof sections are even. What can I do to fix this?
    Thank you
    Edit:
    negative values as suggested by @elton williams worked perfectly. Please see below:
    Attached Thumbnails Attached Thumbnails Inner loops of a footprint sketch may not have slope-defining lines.-bathroom.png   Inner loops of a footprint sketch may not have slope-defining lines.-2651a02c9076fff6ccba172669c9c9aee3c16747.png   Inner loops of a footprint sketch may not have slope-defining lines.-2651a02c9076fff6ccba172669c9c9aee3c16747.png   Inner loops of a footprint sketch may not have slope-defining lines.-bathroom.png
    December 21, 2010
    Phoenix, AZ
    2,584
    12:35 AM
    Build it as multiple roofs and join them together.
    john.warburton likes this.
    Gold Coast
    2,609
    05:35 PM
    You can also use negative values on the outer boundaries.
    August 14, 2018
    8
    07:35 PM
    Cheers GMc, I have used Elton's suggestion and will keep multiple roofs in mind if I get errors.
    June 29, 2015
    100
    08:35 AM
    Have you tried "Align Eaves"? Are you sure the offset from walls are all equal?
    St. Louis, MO
    1,954
    02:35 AM
    You can also use Modify Sub elements and Edit Points to assign a value to each point.
    December 21, 2010
    Phoenix, AZ
    2,584
    12:35 AM
    Quote Originally Posted by cliff collins View Post
    Be careful with that since it changes the thickness of the Roof/Floor when measured perpendicular to the surface -- which, IMO, is a mistake on Autodesk's part.
    August 14, 2018
    8
    07:35 PM
    Quote Originally Posted by asintoras View Post
    Didn't know about 'align eaves'. Thank you (eaves were aligned)
    August 14, 2018
    8
    07:35 PM
    Quote Originally Posted by GMcDowellJr View Post
    Good to know - I've had some crazy glitches doing this with floors
    August 14, 2018
    8
    07:35 PM
    Can I do this with roofs like with floors? Where is the option? Thank you
  1. Slope Lines - Roofs
    By safoulkes in forum Architecture and General Revit Questions
    Last Post: August 22nd, 2013, 03:13 PM
  2. Defining room
    By Ashwini in forum Architecture and General Revit Questions
    Last Post: April 19th, 2013, 05:42 AM
  3. Slab Slope lines
    By LeanneZ in forum Structure - General Questions
    Last Post: August 22nd, 2011, 03:24 PM
  4. Roof by slope, defined sketch, point edits, or other? (2011)
    Last Post: June 9th, 2011, 10:15 PM
  5. Slab slope discrepancy btw "Slope arrow" and "Define Slope"
    By jh75 in forum Structure - General Questions
    Last Post: May 6th, 2011, 08:39 PM
Tags for this Thread
