Results 1 to 3 of 3
Thread: EXPORT via DWG - TXT file not updating
    May 12, 2012
    paris
    91
    12:15 PM
    Hello,
    I spent quite a day optimizing the layer configuration for the export from revit to cad in one revit file. Being satisfied with the results I tested the txt. file for layer set-up on a different revit file. Surprise, the changes I made all day seem to have stayed inside my first revit test file, but not in the txt file !!!
    I was wondering whether there is a way to export a txt file from within revit. The only other way I found was to open the txt file and modify it directly, let's say update it manually - a bit tedious.
    Thanks it advance for your help,
    Kunster
    St. Louis, MO
    1,954
    05:15 AM
    May 12, 2012
    paris
    91
    12:15 PM
    Thanks !
    I forgot about this option, but it would be helpful to have a loadable txt. file.
  1. Navisworks export to KML file
    By MARIA1993 in forum Coordination Tools
    Last Post: November 29th, 2018, 10:30 AM
  2. Help with Walkthrough Export (RAC file attached)
    By darryl in forum Architecture and General Revit Questions
    Last Post: June 19th, 2014, 06:23 PM
  3. Export to DWF file Size
    By sternjohn662200 in forum Architecture and General Revit Questions
    Last Post: December 30th, 2013, 02:52 PM
  4. Lost dwg export file
    Last Post: November 15th, 2012, 01:50 PM
  5. Problem in dwg file import Revit then export gbXML file
    By roczhu in forum Architecture and General Revit Questions
    Last Post: September 2nd, 2012, 11:47 AM
