Results 1 to 1 of 1
Thread: IFC export problem for windows asigned materials
    Moderator gaby424's Avatar
    December 11, 2010
    911
    01:15 AM
    Hello,
    When I use Revit 2019 and export in IFC file (2x3version), I get the glass with the same material as the frames. So in sketchup or in lumion I can’t see them corectly by default.
    The same bug with fbx export. It is like all the windows can have only one material. The bug is with OOTB window or any other custom made ones.
    How did you manage from revit to go around this?
    Do you have this weird revit windows behaviour?
  1. Export DWG layers by materials?
    By yrokkim in forum Architecture and General Revit Questions
    Last Post: June 27th, 2018, 09:11 AM
  2. IFC export - Materials
    By andreakset in forum Architecture and General Revit Questions
    Last Post: November 29th, 2013, 01:44 PM
  3. Can Materials Asigned be Changed Through a Parametric Schedule
    By kamranmirza in forum Architecture and General Revit Questions
    Last Post: August 5th, 2012, 07:16 PM
  4. Export layers by materials?
    By Aparejaducho in forum Architecture and General Revit Questions
    Last Post: April 9th, 2012, 08:48 PM
  5. Export Materials in fbx to 3dsMax problems
    By Ian.Kidston in forum Rendering and Gallery
    Last Post: October 16th, 2011, 08:54 AM
