Results 1 to 3 of 3
Thread: Split Segment Section and glass railing
    December 5, 2018
    2
    12:28 AM
    Hello everyone, i am pretty new here.
    I have a question that hopefully will be easy to answer.
    Why a Glass railing panel disappear from the section once the cutting section is split?
    Orlando, FL, USA
    3,000
    07:28 PM
    Quote Originally Posted by Josh051 View Post
    ...I have a question that hopefully will be easy to answer.
    No, not easy to answer. Please provide more information, screen captures.
    Welcome to Revitforum.
    December 5, 2018
    2
    12:28 AM
    Hello Alfredo sorry for the late reply but I was on holiday.
    Please find a screenshot of the plan and the section that is not showing the balustrade. It is really weird because if the section is straight than the balustrade is visible, if is a guillotine than it disappear as you can see from the screenshots attached.
    Attached Thumbnails Attached Thumbnails Split Segment Section and glass railing-glass-balustrade-plan.jpg   Split Segment Section and glass railing-glass-balustrade-straight-section.jpg   Split Segment Section and glass railing-glass-balustrade-guillotine-section.jpg
  1. Gaps In Segments, Split Segment and multiple levels
    By anthonyB in forum Architecture and General Revit Questions
    Last Post: February 5th, 2014, 12:02 AM
  2. Bug? In split segment
    By sharkmullet in forum Architecture and General Revit Questions
    Last Post: August 25th, 2013, 01:44 PM
  3. split segment on interior elevation view callout?
    By imsureakoto in forum Architecture and General Revit Questions
    Last Post: July 25th, 2013, 03:06 PM
  4. Section and scopeboxes bug - When i try to split the segment it has no effect?!
    By basilmir in forum Architecture and General Revit Questions
    Last Post: May 23rd, 2013, 04:58 PM
  5. Replies: 0
    Last Post: January 29th, 2012, 02:18 PM
