Results 1 to 2 of 2
Thread: Stair Path Arrow not aligning the cut mark
    Junior Member ockf1602's Avatar
    December 3, 2018
    Taiwan
    6
    03:00 PM
    Unhappy Stair Path Arrow not aligning the cut mark
    Hi, I have a second-floor plan with a wrong stair path arrow annotation,
    and I couldn't edit the wrong one to the position I want,
    I've tried modifying the view range of the floor plan and editing the arrow's type property to see something relating to this problem,
    but couldn't find any parameters about this,
    Thanks for any suggestions and replies.
    Attached Thumbnails Attached Thumbnails Stair Path Arrow not aligning the cut mark-stair-path-arrow.png
    December 3, 2018
    Taiwan
    6
    03:00 PM
    I doubt that the problem might be my 1-floor to the 2-floor stair which I drew by sketch method
    because when I edit the cut plan in the view range, the stair path arrow doesn't adapt to the new parameter,
    while the 2-floor to the 3-floor stair which I create with common model does.
    But Revit didn't show me any warning at all.
    Attached Thumbnails Attached Thumbnails Stair Path Arrow not aligning the cut mark-stair-path-arrow-2.png
  1. Stair path arrow (shows reversed)
    By DesignApparatus in forum Architecture and General Revit Questions
    Last Post: August 8th, 2016, 10:07 PM
  2. Stair Tread Obscuring Stair Path Arrow
    By Manderson in forum Architecture and General Revit Questions
    Last Post: June 23rd, 2016, 07:22 PM
  3. stair path/ thread number not working with stair by sketch
    By carlotristan in forum Architecture and General Revit Questions
    Last Post: October 12th, 2015, 01:19 AM
  4. stair path to show full length of stair REVIT 2015
    By ledgewood33 in forum Architecture and General Revit Questions
    Last Post: May 28th, 2015, 06:30 PM
  5. Stair levels aligning
    By veuxx in forum Architecture and General Revit Questions
    Last Post: January 14th, 2014, 03:59 PM
Tags for this Thread
