Page 1 of 2 12 LastLast
Results 1 to 10 of 12
Like Tree3Likes
Thread: Scale
    October 17, 2018
    68
    06:52 AM
    Scale
    Hello to everyone,
    I am at the moment updating the sheet template of my company. The issue is related to the scale of the drawings that i am relating at the legend. In the picture you can see the name "ESCALAS" its scale in portuguese, my native language. In the front of "ESCALAS" is label named "Indicadas" it means indicated in the current drawing of the project. What I would like is that the "Indicadas" or "Indicated" actually show the scales of the drawing that I have on the sheet that I am currently presenting.
    Best regards
    Senior Member kamranmirza's Avatar
    January 12, 2011
    London, UK
    534
    07:52 AM
    It will only show the scale IF there are/is ONLY viewports with one scale. As soon as you have viewports with different scales, it will show 'as indicated' and you have to use the view title to indicate the scale.
    June 21, 2012
    Tours, France
    947
    08:52 AM
    Hi ppatricio as Kamran already said that text will show up automatically when you have multiple scales in your sheet, I've already faced the same issue and what I'm doing here is to put another "Label" with a visibility parameter and a simple yes/not formula which allows me to control the text since here in France the "As Indicated" text is not useful, see image, that way you can write you own text or as in my case put manually the main scale, hope this can help you! best regards
    October 17, 2018
    68
    06:52 AM
    But in my current drawing,a s you can see I only have one drawing...
    Best regards
    January 12, 2011
    London, UK
    534
    07:52 AM
    Quote Originally Posted by ppatricio View Post
    as you can see I only have one drawing...
    Only one viewport ? You may have a legend placed on the sheet: they also have a scale and if the legend's scale is different from the viewport, it will return a 'as indicated' label.
    January 19, 2012
    325
    01:52 AM
    A rule of thumb for my Legends are to always scale them per what my Main plans will be at (either for overalls, partials, or enlarged). That way my sample graphics/Legend Elements will always align to the referencing scale.
    January 12, 2011
    London, UK
    534
    07:52 AM
    Quote Originally Posted by cftrevizo View Post
    A rule of thumb for my Legends are to always scale them per what my Main plans will be . . .
    Yeah, only figured that out recently a few months ago.
    October 17, 2018
    68
    06:52 AM
    I have two viewports in this case for exemple, as you can see throught the picture that I am uploading... Both have a scale of 1/100. Bit the scale come as indicated....
    St. Louis, MO
    1,954
    01:52 AM
    Perhaps there is another view on the sheet at a different scale, which is hidden?
    November 2, 2011
    Slaithwaite ("Sla wit"), W Yorks, UK
    240
    07:52 AM
    If you expand the sheet name in the Project Browser it will list all of the views on the sheet. That would help to identify if there is a view that is hidden or placed outside the sheet extent.
  1. scale
    By aamirtanoli in forum MEP - General
    Last Post: March 7th, 2015, 06:48 PM
  2. Not to scale
    By chris.macko in forum Architecture and General Revit Questions
    Last Post: August 29th, 2014, 02:03 PM
  3. Grids showing on 1/8" Scale drawings; same grids missing from 1/4" Scale drawings
    By revit_user in forum Architecture and General Revit Questions
    Last Post: April 22nd, 2013, 02:36 PM
  4. Not To Scale
    Last Post: May 4th, 2012, 09:12 PM
  5. Scale?
    Last Post: June 28th, 2011, 09:32 PM
