Results 1 to 3 of 3
Like Tree1Likes
  • 1 Post By cellophane
Thread: Dimension tool to align objects not working
    September 21, 2016
    Boston
    168
    08:21 PM
    I am not understanding the logic behind how Revit equally positions objects utilizing the dimension tool.
    I have a lighting fixture (movable, not pinned) which I want to center in-between detail lines that are deliberately fixed in place (pinned) for the purpose of centering the lighting fixture in between the two.
    When I add a dimension string, and select the "EQ," it gives me an error message: "Constraints are not satisfied"
    I am not sure why this is happening, since there are two fixed points, and the lighting fixture is not pinned or fixed in any manner.
    Logic would dictate that the unconstrained lighting fixture move to be equidistant between the two pinned detail lines when I select the EQ option, since it's the only non pinned object in the equation.
    Any ideas?
    St. Louis, MO
    1,954
    06:21 PM
    Perhaps there is a constraint in the light fixture family which is conflicting with the EQ constraints in the project.
    Moderator cellophane's Avatar
    August 9, 2011
    Louisville, KY
    6,031
    07:21 PM
    Revit gives precedence to the model object over the detail lines. If you use model lines or reference planes the EQ constraint will work as expected.
    tuekappel likes this.
  1. Align dimension not working properly
    By perewesley in forum Architecture and General Revit Questions
    Last Post: September 5th, 2017, 02:09 PM
  2. Align tool not suitable
    By Ecotech Kid in forum Architecture and General Revit Questions
    Last Post: April 8th, 2016, 05:34 PM
  3. Revit OpEd: AutoCAD 2015 Tip - Align Tool
    Last Post: April 2nd, 2015, 01:15 AM
  4. Align Dimension Square Grip Not appearing
    By Lilly in forum Architecture and General Revit Questions
    Last Post: January 19th, 2014, 11:33 AM
  5. Angle Parameters - Cant align a dimension in a generic model family
    By sambarr88 in forum Architecture - Family Creation
    Last Post: July 21st, 2013, 10:56 PM
