Results 1 to 8 of 8
Thread: 2019 Can't toggle Projection mode
    Moderator DaveP's Avatar
    January 10, 2011
    St Paul, MN
    2,965
    02:19 AM
    Any idea why my "Projection mode" parameter is greyed out?
    I've got another View with the same View Template that I can change it.
    The View is not locked or assigned a Scope Box.
    I can't think of anything else that would affect the Projection Mode
    Member pivoarch's Avatar
    March 16, 2011
    Princeton, NJ
    304
    03:19 AM
    Pinned? The drastic difference in eye elevation and target elevation? Just throwing darts here.
    St. Louis, MO
    1,954
    02:19 AM
    View Cube setting?
    June 7, 2016
    38
    11:19 PM
    Its because you have it placed on a sheet. They disable the ability to make an uncropped perspective view when it is placed on a sheet.
    January 10, 2011
    St Paul, MN
    2,965
    02:19 AM
    Quote Originally Posted by ocrender View Post
    DING DING DING !!!!
    We have a winner !!
    oc nailed it. That 3D View was, indeed, on a Sheet.
    I would also explain why, when I duplicated it, the Duplicated view did allow me to change Projection Mode.
    New tools, new quirks, I guess.
    It makes perfect sense that you can't screw it up once it's on a Sheet. Just have to remember that.
    Thanks, everyone.
    Moderator cellophane's Avatar
    August 9, 2011
    Louisville, KY
    6,124
    03:19 AM
    Why would being on a sheet make a difference if the view is perspective or orthogonal? I can change everything else about the view once it is on a sheet, there is no reason this couldn't be changed as well
    St. Louis, MO
    1,954
    02:19 AM
    Maybe something to do with "uncropped perspective" new feature in Revit 2019?
    March 16, 2011
    Princeton, NJ
    304
    03:19 AM
    Because.....reasons Chad....reasons.
  1. Change from full render mode to shaded mode in an animation
    By Carchee in forum Coordination Tools
    Last Post: August 9th, 2016, 05:15 PM
  2. Elevation Projection
    By theshell07 in forum Architecture and General Revit Questions
    Last Post: February 5th, 2014, 06:14 PM
  3. Replies: 0
    Last Post: September 17th, 2013, 11:15 AM
  4. Oblique projection in revit
    By Nathaniel101789 in forum Architecture and General Revit Questions
    Last Post: November 20th, 2011, 12:58 AM
