Results 1 to 4 of 4
Thread: Elevation callout vanishes with change in level offset
    July 10, 2015
    Boise, Idaho
    579
    09:09 PM
    I have a project where each of the floors is offset from the level (see previous discussion https://www.revitforum.org/architect...oped-site.html)
    That went great. Thanks for the advice. Now that I'm finished modeling I'm having trouble with the interior elevations. As I crop the elevation to the appropriate heights the elevation callout loses the tag calling out where the view is located. The tag for the sheet remains though.
    In particular the view that prompted me to ask is on the 2nd floor. The base of the walls are offset 8'-6". Plan regions have covered all the modeled elements nicely. But I lose my elevation callouts. What am I missing to get the callout to display properly?
    Mr. Revit OpEd
    2,736
    08:09 PM
    I believe you need to leave the extent of the view intact. Use a masking region to hide the lower information in the view.
    July 10, 2015
    Boise, Idaho
    579
    09:09 PM
    That's a bit of a bother. The views will extend off the sheet if I do that
    St. Louis, MO
    1,952
    10:09 PM
    Perhaps use a Ceiling Plan which should show the elevation tags, as it seems like a cut-plane/view range problem with the floor plan?
  1. Change New Floor Plans Properties: Detail Level, Elevation, etc.
    By samz1 in forum Third party Add-Ins, API and R&D
    Last Post: May 15th, 2014, 06:03 AM
  2. Elevation Callout Tag
    Last Post: November 12th, 2012, 05:12 PM
  3. How to change Level Arrow symbol in Elevation Indicators
    By willsud in forum Architecture and General Revit Questions
    Last Post: April 4th, 2012, 01:55 PM
  4. Know the offset from level
    By JTB in forum Architecture and General Revit Questions
    Last Post: May 12th, 2011, 11:36 AM
  5. Detail Callout on Framing Elevation?
    By LeanneZ in forum Architecture and General Revit Questions
    Last Post: March 14th, 2011, 07:48 PM
