Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Like Tree9Likes
Thread: Create parking space + road etc - Suitable tool
    October 16, 2016
    397
    06:05 PM
    Hello all,
    What tool are you use in order to create roads, embankments in the side of the road and parking spaces with dofferent slopes?
    I tried once creating multiple building pad but the connection wasn't very good.
    Thank you in advance!
    Moderator cellophane's Avatar
    August 9, 2011
    Louisville, KY
    6,104
    02:05 PM
    Roofs seem to be the most common option since they can be shape edited and you can use fascia for things like curbs pretty easily.
    cganiere likes this.
    October 16, 2016
    397
    06:05 PM
    Roof tool for the roads?
    So, many roofs in order to have different slopes?
    How I will 'stop' the toposurface in the level that I want? I need to create pads, no?
    July 10, 2015
    Boise, Idaho
    641
    12:05 PM
    Roofs. Easy to model, slope, add curbs (as fascias), etc.
    October 16, 2016
    397
    06:05 PM
    And which tool do you use for the embankments ?
    Attached Thumbnails Attached Thumbnails Create parking space + road etc - Suitable tool-embankments-talus.png
    December 20, 2010
    1,045
    02:05 PM
    Depends, if you are modeling your site with topography, the subregions. If roofs, then you would have to either paint the surface of the transition or best would be in the image there you would have 3 roofs, one main one (in the exact shape you show), then a second one for the embankments. You would use the opening tool to cut the main roof out for the location of the embankments, then use the opening tool on the embankments to cut out the grass area.
    tidalwave1 likes this.
    Senior Member biff's Avatar
    June 13, 2011
    Australia
    844
    04:05 AM
    Maria,
    Two schools of thought I think are existing here.
    Model entirely with topo and adjust and manipulate points then create subregions on the topo to indicate the material change
    Or forget using topo tool, and make the whole topo out of roofs.
    The only way I have used both is to lay the roofs down, (for a carpark that needs drainage to centre for instance, therefore one pad doesn't work), then modify topo to adjust its height in the same area as the roof so the topo sits neatly under the roof. Took me a while, but hey it was learning and fun.
    I have always wanted basic hardscaping ability in revit by having pads that allow points.
    October 16, 2016
    397
    06:05 PM
    Quote Originally Posted by sdbrownaia View Post
    My idea is to create the natural toposurface. And after to start to modelise the new toposurface with the parking spaces, slopes etc etc. (We want to see the form of the toposyrface)
    The subregions change only the surface, cannot define the slopes with these.
    If I create a pad in order to 'cut' the toposurface and after use floors/roofs for the parking spaces? (And after to put the parking scpace family and host to the roof/floor that i will have created?
    If I want to be very precise with the slopes and the embankments, do I need to use other software? I have the impression that with Revit the function to create these elements precise is limited. Am I wrong?
    Thank you a lot for your ideas.
    Gold Coast
    2,602
    04:05 AM
    Quote Originally Posted by MARIA1993 View Post
    You are not wrong, Revit is TERRIBLE for accurate siteworks. Always has been. Youll get far more mileage out of civil 3D etc
    October 16, 2016
    397
    06:05 PM
    So is it a good idea to create the siteworks in Civil3D and after import it in Revit in order to create our plans? [ I think that I need also a BIM360 account..]
    Thank you!
  1. Align tool not suitable
    By Ecotech Kid in forum Architecture and General Revit Questions
    Last Post: April 8th, 2016, 05:34 PM
  2. How Create a Zone for Each Space easily
    By kvusal in forum MEP - General
    Last Post: March 20th, 2016, 03:45 PM
  3. How to use the Parking Space Components in the Upper Level Floors?
    By littlebear in forum Architecture and General Revit Questions
    Last Post: May 29th, 2014, 04:08 PM
  4. Create road hump with zebra line on top
    By abc88 in forum Architecture - Family Creation
    Last Post: July 20th, 2012, 07:37 AM
  5. Error: There is not enough space on drive C: to create...
    By darryl in forum Architecture and General Revit Questions
    Last Post: April 6th, 2011, 01:06 PM
