Results 1 to 3 of 3
Like Tree1Likes
  • 1 Post By cellophane
Thread: Roofs in the same plane
    Member Cyus's Avatar
    July 10, 2012
    London / MK
    490
    02:23 PM
    This is an issue that I seem to come across often. I have a main roof, and then a smaller feature roof which sits in the same plane (so I am unable to model it as part of the main roof). When I model it as a separate roof, I can use the Join/Unjoin roof tool to project to the main roof, except when the eaves is in the same plane. In that instance, I get the error message 'The roof cannot be joined'
    I can move the smaller roof 1mm away from the main roof and model it that way, however then the fascia doesnt join neatly between the two roofs. See attached images.
    Is there a solution for this?
    Attached Thumbnails Attached Thumbnails Roofs in the same plane-img01.jpg   Roofs in the same plane-img02.jpg
    July 10, 2012
    London / MK
    490
    02:23 PM
    Seems the solution is to make a vertical opening in the larger roof which matched the valley profile. Then the smaller roof will join to it.
    Moderator cellophane's Avatar
    August 9, 2011
    Louisville, KY
    6,124
    09:23 AM
    That is pretty easy to do with slope arrows as well.
    you need to split your roof sketch into 3 lines. The middle line (the part that gets the slope arrows) can't be slope defining. Then place your slope arrows and set them to Slope (height would also work)
    Attached Thumbnails Attached Thumbnails Roofs in the same plane-roof-inlinegable.png
    Attached Files Attached Files
    willsud likes this.
  1. Replies: 0
    Last Post: November 27th, 2016, 07:45 AM
  2. Wishlist - Right-click on named reference plane, set as work plane.
    By ryntau in forum Architecture - Family Creation
    Last Post: September 22nd, 2015, 04:30 PM
  3. How to move 2D elements on flat plane to vertical plane??
    By lukewallace1990 in forum Architecture - Family Creation
    Last Post: December 6th, 2012, 08:31 AM
  4. Family Cut plane versus Project Cut Plane
    By cellophane in forum Tutorials, Tips & Tricks
    Last Post: October 2nd, 2012, 02:22 AM
  5. how i can make offseted lines to refrence plane move along refrence plane?
    By ahmed_hassan in forum Architecture - Family Creation
    Last Post: October 17th, 2011, 04:40 PM
