Results 1 to 4 of 4
Like Tree1Likes
  • 1 Post By Robin Deurloo
Thread: Curtain Walls
    October 11, 2018
    Ohio
    3
    09:58 AM
    Curtain Walls
    I design Greenhouses so obviously I use mainly Curtain walls. In order to put regular doors in I have to embed a basic generic wall into the curtain wall to get the door to work. Every time I have to move or do anything with the curtain wall it deletes the door or anything else I have attached to the embedded wall. My question is why does it do this if it not attached to the curtain wall??
    Coeur d Alene, ID
    4,744
    06:58 AM
    Why don't you use a curtain wall door? You can build them so they don't flex with the grid lines.
    They are a bit outdated....but check out how Aaron did his curtain wall doors here: https://www.revitforum.org/architect...-v4-r2015.html
    July 7, 2011
    Rotterdam, Holland
    1,205
    03:58 PM
    Just build a curtain panel that looks like a door. You can even load your door into a Curtain Panel family and use that.
    That is how my design door/windows work
    j_cornelius likes this.
    October 11, 2018
    Ohio
    3
    09:58 AM
    Thank you I'll have to try that out.
  1. Curtain Walls - Location relative to adjacent walls
    By BLothian in forum Architecture and General Revit Questions
    Last Post: January 16th, 2018, 11:18 PM
  2. Curtain Walls
    By aaronsmith0707 in forum Architecture and General Revit Questions
    Last Post: October 16th, 2017, 09:29 PM
  3. Curtain walls
    By Chamferman in forum Out There
    Last Post: January 3rd, 2015, 03:33 PM
  4. Visibility in 2014 Walls vs Curtain Walls
    By DaveP in forum Architecture and General Revit Questions
    Last Post: September 10th, 2013, 08:57 PM
  5. Curtain Walls
    By jergreen in forum Structure - General Questions
    Last Post: June 29th, 2012, 09:40 PM
