Results 1 to 4 of 4
Thread: View Templates
    June 17, 2011
    Nelson, BC, Canada
    8
    07:05 AM
    View Templates
    Does anyone know if it's possible to copy the VG overrides and other view parameters from a plan view template to a section view template or vise versa? When I open the 'Manage View Templates' window, I am able to duplicate a view template but have no option to duplicate it to a different view type - i.e. if I want to duplicate a floor plan view template, it creates an identical plan view template with the same parameters and different name. I would like to apply those same view parameters to a section, elevation, or different type of view.
    January 19, 2012
    325
    09:05 AM
    June 17, 2011
    Nelson, BC, Canada
    8
    07:05 AM
    Thanks cftrevizo, but that didn't help. I don't think this applies to what I am trying to do or I don't fully understand it. I'm not using VG filters but am concerned with duplicating view templates. I've edited my post to add more description.
    June 17, 2011
    Nelson, BC, Canada
    8
    07:05 AM
    Quote Originally Posted by cftrevizo View Post
    I think I just figured it out. I assumed you couldn't apply a vertically oriented view template (section, elevation, etc.) to a plan view but you can! Vertical and horizontal views have different options in the 'Extents' menu inside the Properties palette but you can set the appropriate values for each.
  1. View Templates for Sections
    By evan.dodds in forum MEP - General
    Last Post: May 17th, 2017, 06:19 PM
  2. Add Filter To All View Templates
    Last Post: November 17th, 2016, 02:43 PM
  3. View Templates
    By BoBMudd2 in forum Architecture and General Revit Questions
    Last Post: December 18th, 2014, 03:35 PM
  4. Templates : Placeholder Links + View Templates
    Last Post: February 8th, 2014, 09:15 AM
  5. View Templates
    By blassen81 in forum MEP - General
    Last Post: January 18th, 2014, 10:54 PM
