Results 1 to 5 of 5
Like Tree1Likes
  • 1 Post By DaveP
Thread: Exorting Revit to Autocad
    January 18, 2017
    Eden Prairie, MN
    75
    08:37 AM
    I am exporting a Revit drawing that contains a raster image to dwg format. When the dwg is opened in AutoCAD, the raster image is rotated or not there at all. I can't select it in AutoCAD to move it into the correct position. Is there anyway to prevent this from happening when exporting a Revit file?
    Moderator DaveP's Avatar
    January 10, 2011
    St Paul, MN
    2,965
    08:37 AM
    I kind of like the idea of "Extorting" as the only reason to use AutoCAD.
    But seriously, folks.
    I can't explain why it rotated upon export, but if I remember my command line correctly, there's a SETVAR name IMAGEFRAME that determines if you can select an image and/or it's outline. Don't remember which setting does which, but its either 0, 1, or 2
    Andres Franco likes this.
    November 2, 2011
    Slaithwaite ("Sla wit"), W Yorks, UK
    240
    02:37 PM
    Aren't raster images exported as external elements when exporting DWGs from Revit? If you send those along with the DWG, the user should be able to reinsert them if they need to.
    June 21, 2012
    Tours, France
    948
    03:37 PM
    yes that's exacly the command, by the way the rotated images I've never saw that, and I do a lot of export to DWG
    Coeur d Alene, ID
    4,744
    06:37 AM
    Insert the image in an annotation symbol then into the project. That way you can resize at the family level before placing. Seem to fix the resize/rotating issues.
  1. Replies: 3
    Last Post: March 11th, 2014, 09:35 PM
  2. Replies: 0
    Last Post: February 5th, 2013, 11:15 AM
  3. Replies: 0
    Last Post: September 24th, 2012, 11:16 AM
  4. Replies: 0
    Last Post: September 7th, 2012, 11:15 AM
  5. Replies: 0
    Last Post: November 18th, 2011, 03:15 AM
