Results 1 to 5 of 5
Like Tree2Likes
  • 1 Post By Robin Deurloo
  • 1 Post By willsud
Thread: Revit 2019 Issues
    April 14, 2014
    66
    05:49 PM
    Revit 2019 Issues
    I am having some weird issues with Revit 2019. First of all, it occasionally crashes. Just closes and straight to Windows desktop with no warning or error. I have the latest 2019.1 patch installed and it didn't help. I have also had performance issues with it, worse than previous versions, as well as frequent join warnings that do not seem to equate actually to anything, things are unjoining and then automatically rejoining for no apparent reason.
    I have also noticed that every time I load a family, straight out of the RVT 2019 families folder, it says updating from Revit 2017 to 2019. This one just seems straight up bizarre to me.
    Should I try to download another copy? I got it straight from the source at Autodesk (part of the Suite), from the subscription page. I kind of wish I stuck with 2018 for now.
    July 7, 2011
    Rotterdam, Holland
    1,233
    11:49 PM
    I had the crash thing with 2018 when I installed some plugin, de-installed that and all was well again, so maybe check that.
    Performance should be the same or maybe even better then 2018 are you sure your machine is OK with running Revit (obvious question, but got to ask).
    No idea about the warnings, so far have not seen anything different compared to 2018.
    The RVT 2019 family folder is the one that comes with installing revit 2019? If so it seems like Autodesk might have forgotten to update the families. If it is your own family folder, you will have to upgrade all your families to 2019. I have never used an OOTB family, so can not tell you if that is the case.
    And I do hope you tested 2019 before you updated all your projects. You can always finish your projects in 2018 (unless they are all updated to 2019).
    cganiere likes this.
    December 13, 2010
    Ambleside, Lake District, UK
    950
    10:49 PM
    There was a post in the forum a while ago about a known issue with general slowdown in Revit 2019 if you had the Roombook extension installed - not sure if Autodesk have fixed that yet.
    It may be completely unrelated but I only had issues with Revit 2019.1 via Windows 10 updates - update build 1803 in particular - and conflicts with Office 365. Attempting to uninstall Office 365 was a very bad idea and in the end I had to reinstall Windows 10 from scratch and now everything is lovely - although it took 12 attempts
    therrien likes this.
    June 21, 2011
    6
    04:49 PM
    We have been recently having this issue with 2019.1 on 360. This occurs at random on both Windows 7 and Windows 10 machines.
    Mr. Revit OpEd
    2,882
    02:49 PM
    Generally ill advised to mix Operating System versions among users contributing to the same project files. Same goes for Revit builds.
  1. Revit extensions 2019
    By CAD Services and Design in forum Architecture and General Revit Questions
    Last Post: October 12th, 2018, 03:23 PM
  2. Replies: 0
    Last Post: August 21st, 2018, 01:45 PM
  3. Is Revit 2019 broken?
    By elton williams in forum Architecture and General Revit Questions
    Last Post: June 4th, 2018, 06:15 AM
  4. Replies: 0
    Last Post: May 2nd, 2018, 09:15 AM
  5. No Revit 2019 for AEC IC subscription yet?
    By cellersick in forum Architecture and General Revit Questions
    Last Post: April 18th, 2018, 05:44 PM
