Results 1 to 4 of 4
Like Tree1Likes
  • 1 Post By cellophane
Thread: Editing a beam system
    February 16, 2016
    102
    07:23 AM
    Can anyone help me here?
    I have created a beam system in Revit. Only trouble is I placed it rather too low.
    It seems you can adjust the geometric justification z position of a single beam.
    Justification I understand as the setting out point. So if I alter it from top to bottom I actually move beam up by depth of beam.
    But if I edit the whole beam system, things are not so simple. Justification here seems to mean something totally different. Options are:
    Beginning
    End
    Centre line
    Direction line
    I alter all these and nothing seems to happen. How do I edit a beam system once it has been placed and move it all up by depth of beam as I did with one?
    Moderator cellophane's Avatar
    August 9, 2011
    Louisville, KY
    6,124
    03:23 AM
    You can change the elevation of the beam system or change the work plane to adjust the z position.
    https://www.screencast.com/t/HqCbssY001AY
    kamranmirza likes this.
    February 16, 2016
    102
    07:23 AM
    Thank you for video.
    I am having a great deal of difficulty in reproducing effects at my end.
    You say:
    Fine, well in video at 0:08 under Constraints, elevation of beam system can be changed.
    However, when I try to do this, Constraints are all greyed-out and elevation input option is nowhere to be seen (see attached image).
    Why is that?
    How for that matter do you draw a convincing junction between rafter and ridge board? (see second attached image).
    I have tried using command such as beam/column joins but that does not seem to work.
    Regards
    Attached Thumbnails Attached Thumbnails Editing a  beam system-beam-system-17-10-18.jpg   Editing a  beam system-ridge-17-10-18.jpg
    Orlando, FL, USA
    3,093
    03:23 AM
    Try this: From a 3d view, Architecture > Set > select the underside face of the roof as the current workplane. Now select the beam system. > from the ribbon, Pick New > workplane. Move the beam system to the new workplane. The default justification of the beams is "Top". If you haven't changed that, now all the beams in the beam system should be having the top face under the bottom surface of the roof.
  1. Beam system and Roof - gap
    By sknsnw9 in forum Architecture and General Revit Questions
    Last Post: September 14th, 2015, 03:33 PM
  2. How can I create a Beam System Tag to show Beam Type Mark or Beam Mark
    By gpktm in forum Structure - General Questions
    Last Post: September 10th, 2015, 04:44 PM
  3. Question on manipulating/editing system families.
    By GorG03 in forum Architecture - Family Creation
    Last Post: April 23rd, 2014, 01:21 PM
  4. Beam System Justification
    By kowen1208 in forum Structure - General Questions
    Last Post: January 22nd, 2014, 04:43 AM
  5. Fire protection system editing
    By felipe.villete in forum MEP - General
    Last Post: November 1st, 2012, 10:26 AM
