Results 1 to 7 of 7
Like Tree1Likes
  • 1 Post By elton williams
Thread: Possible to copy "View Types" from linked model
    March 27, 2014
    117
    12:11 AM
    We're working with a few models and a recently updated Revit Template. I'm using Project Transfer to copy various categories from the new template to the models I'm working on but it seems it's not possible to copy "View Types" between the project (eg below). I have view templates assigned to the view types which would be quite time consuming to setup again.
    Does anyone now a workaround using Dynamo or other plugins?
    Member Raff's Avatar
    June 13, 2014
    @EIMHINATWORK
    96
    12:11 AM
    would "Insert view from file" work for you? do you have a base level or datum level in common between the files?
    March 27, 2014
    117
    12:11 AM
    Doesn't seem to be possible Raff
    Attached Thumbnails Attached Thumbnails Possible to copy "View Types" from linked model-capture.jpg
    Gold Coast
    2,463
    10:11 AM
    Draw a callout of your specific view type. Copy/ paste that into your new project. Using Revit lookup you can find the ID of of both view type and template, select both by ID and copy /paste those over.
    Andres Franco likes this.
    March 27, 2014
    117
    12:11 AM
    Thanks, that seems to do the job!
    I had read about Revit Lookup, they can be difficult here about installing software so the manual method of creating callouts to copy works better. It won't be a problem on project starting with the updated template.
    ---EDIT---
    This method brings in the view but not associated type
    Gold Coast
    2,463
    10:11 AM
    Quote Originally Posted by Jozi View Post
    ---EDIT---
    Then you're doing something wrong as it works for me 100% of the time.
    March 27, 2014
    117
    12:11 AM
    Thinking about it now, I think maybe do not apply view template is assigned to the view type. Not at my computer right now but this is probably why.
  1. Linking models into a "central" model file, linked views and view templates
    By DesignApparatus in forum Architecture and General Revit Questions
    Last Post: May 18th, 2018, 05:39 AM
  2. linked dwg file "disappears" when zooming in view
    By jh75 in forum Architecture and General Revit Questions
    Last Post: February 4th, 2013, 12:41 AM
  3. Can't control the "By linked view" of linked model
    By alexo4141 in forum Architecture and General Revit Questions
    Last Post: November 22nd, 2012, 09:44 PM
  4. Hiding "Spaces" from linked MEP model
    By devinmccarthy in forum Architecture and General Revit Questions
    Last Post: September 19th, 2012, 03:56 PM
  5. Perspective view of Revit linked files shows "phantom" elements
    By Andre Carvalho in forum Architecture and General Revit Questions
    Last Post: March 25th, 2012, 03:46 PM
