Results 1 to 10 of 10
Like Tree3Likes
  • 1 Post By cheinaranta
  • 1 Post By Robin Deurloo
  • 1 Post By Knitro87
Thread: Structural and architectural project
    October 16, 2016
    419
    04:36 AM
    Hello all,
    I have noticed that there are many projects in Revit, where the people separate in two different Revit Projects the architectural and structural part.
    So in the architectural project there are all the architectural elements (walls of isolation, doors, toposurface etc.) and in the structural model there are the structural walls, the structural floors, the columns etc.
    How do you organise your model? Do you also divided them in two Revit projects?
    In order to do that, do I need to make the model (archirectural + structural) in a single Revit file and after 'move' the structural elements in a secondary Revit Project?
    Thank you in advance!
    May 18, 2011
    Calgary, AB
    410
    10:36 PM
    Utopian BIM there is only one model.
    Reality BIM, there is an architectural model and a structural model. Depending on size or if multiple firms work jointly, you might have multiple models of the same discipline. I work for a firm that has A/S/M/E under one roof. We've tried the all in one model. Doesn't work that well (at least for us and that was early on in our Revit maturity). We'll always have separate discipline models even if we are all on one project.
    I wrapped up a renovation to an existing tower. I modelled the existing structure in the architectural model and was responsible for the demolition of those structural elements. Structural (out of house) was responsible for any of the new structure and did so in their own model.
    A lot of times I'll see Architectural model some sort of structure early on in the design to have "something" so their drawings look good for design presentations. Structural will come later on and start doing their thing using what we had as a guide. At some point you'll remove certain elements out of your model as Structural starts to develop the structure further and you'll rely on their model to represent the structure.
    You'll have to have a discussion about what do you do about stairs, structural walls that host doors etc. Plenty of threads covering those topics.
    cganiere likes this.
    July 7, 2011
    Rotterdam, Holland
    1,293
    06:36 AM
    Quote Originally Posted by cheinaranta View Post
    Yep that's what I do usually.
    Project I'm working on now, the prefab concrete stairs are in the structural model, wooden or steel ones are in the architectural one.
    Hosted stuff is always tricky. I have no hosted families except doors and windows and I have placed doors that are in a structural wall in a piece of wall that is inside the void in the structural wall. You can see that as the piece of wood they use IRL to mount the door in the wall.
    The only thing that is annoying (to my clients mostly) is the fact that you are waiting for the other party to finish their work before you can finish yours. For example I have loads of doors already sitting in my model, at the right location, but the structural guy has not made the openings in the walls yet and every time I get a remark that there is still concrete there from the architect and also from the guy doing clash control. But that is something you just have to ignore after you tell them it is not your wall that needs the opening the first time.
    July 10, 2015
    Boise, Idaho
    700
    10:36 PM
    We create an architectural model. The structural engineers wail and gnash their teeth at the thought of copy monitor so they remodel everything (usually incorrectly). We link their model in, use filters to turn off all of their junk. Call them every project and tell them to resend it with the levels and grids on the right workset. Reload their revised model, find they still didn't get it right. Go into their model, put the stuff on the right workset. Relink it, apply filters, wonder why after so many years of using Revit this is still the thing they can't understand. I think it's like the old paperspace. Engineers are frightened and enraged by it.
    Member Knitro87's Avatar
    December 3, 2014
    Austin, TX
    284
    11:36 PM
    Quote Originally Posted by DavidLarson View Post
    ...Call them every project and tell them to resend it with the levels and grids on the right workset. Reload their revised model, find they still didn't get it right. Go into their model, put the stuff on the right workset.
    *pulls out magnifying glass...*
    Whoa! It looks like levels and grids DO have their own annotation category! Now, if there was only a way to turn off those categories through some sort of RVT Link Display Settings, and then create a template from these settings dedicated specifically for views. Hmmm...
    I'm mostly just being facetious. Not all structural engineers are bad.
    My ID was stolen. Now I'm only called Dav
    p.s. Nice dad joke. Now take your kudos and get outta here.
    DavidLarson likes this.
    June 5, 2011
    85
    05:36 AM
    Isn't that what they are paid to do? Do some work and create their own model rather than use all your hard work?
    We recently did a project in another application, structural engineers complained so badly that it was not in Revit, meaning they had to do some work rather than use our models, the client nearly forced the use of Revit on us.
    Luckily buzz phrases like "BIM maturity" saw the structural engineers back down.
    October 16, 2016
    419
    04:36 AM
    Hello all,
    Thank you for your time.
    First of all, does the method that you use in order to create the structural model from the architectural the copy/monitor? Or do you use another method?
    Secondly, if you have a wall with concrete and 3 layers insulation, do you create four different walls? A concrete wall structural, and 3 different walls for each type of insulation or do you create the 3 layers of insulation in a wall architectural type?
    September 23, 2015
    193
    12:36 AM
    Hi Maria,
    Walls that are not partitions are usually modeled as separate walls. I do not copy monitor the entire structural model, but rather only walls where I am hosting elements such as doors, storefronts and windows.
    Columns, framing and slabs are linked directly.
    this is a conversation you should have with the Revit leads of each discipline.
    October 16, 2016
    419
    04:36 AM
    Quote Originally Posted by Profoxcg View Post
    Hi Maria,
    Why do you copy these walls and don't create them by your own?
    Thank you !
    September 23, 2015
    193
    12:36 AM
    I should have been more clear. I create them, put doors in them, then once I get the S model back, I monitor them visually. Howver the structural engineer does copy monitor them, along with levels and slabs.
    What I also do is add parameters in those objects that are structural in nature but that I created in the arch model so that I can use view filters down the line to either hide them of compare them.
    Shearwalls or wall where I am hosting doors and windows aren't linked from the structural model, I keep a "copy" of them in the arch model.
  1. Separate Architectural and Structural?
    By cbaze in forum Architecture and General Revit Questions
    Last Post: September 28th, 2018, 01:29 PM
  2. doing both architectural and structural in one in revit, and 3D
    By chrissull in forum Structure - General Questions
    Last Post: May 28th, 2018, 07:30 AM
  3. structural model misplaced from architectural model in Revit Architectural 2014
    By rayanjreije in forum Architecture and General Revit Questions
    Last Post: March 13th, 2014, 08:51 PM
  4. Collaboration between Architectural and Structural firms.
    By Scott Deslippe in forum Architecture and General Revit Questions
    Last Post: June 19th, 2013, 08:04 PM
  5. Architectural and Structural Coordination and Collaboration
    By anthonyB in forum Architecture and General Revit Questions
    Last Post: January 31st, 2013, 01:22 AM
