Results 1 to 3 of 3
Thread: 2015- railing balusters do not cast shadows and no glazing transparency
    February 5, 2012
    47
    05:53 PM
    Good Morning:
    Working on a project for a client doing modeling of a residential unit. They have picked a specific railing of balusters and rails. In plan, the balusters do not cast shadows while the rails do.
    Also, when using glazed curtain panels, the glazing is casting a solid shadow. I have hid the panels so that only the mullions are visible to accurately cast a shadow. Is there someway to make glass cast a semi-transparent shadow?
    Working in 2015 as that is the platform they are on.
    Thanks.
    2015- railing balusters do not cast shadows and no glazing transparency-plan.png
    2015- railing balusters do not cast shadows and no glazing transparency-3d.png
    Senior Member kamranmirza's Avatar
    January 12, 2011
    London, UK
    534
    06:53 PM
    As for the balusters not casting a shadow, I'd guess that they are unticked in the family so they don't show in plan. Check the visibility/Graphics/Overrides in the properties window.
    2015- railing balusters do not cast shadows and no glazing transparency-vgo.jpg
    February 5, 2012
    47
    05:53 PM
    Quote Originally Posted by kamranmirza View Post
    Wow, Totally thought the round baluster was a system family and not editable. Now I know. That did the trick...
  1. Can anybody provide guidance on a railing that has both balusters and vertical cables
    By DesignApparatus in forum Architecture and General Revit Questions
    Last Post: September 6th, 2017, 12:27 PM
  2. Transparency deprecated in 2015, recommended alternative not working
    By Eddy Vluggen in forum Third party Add-Ins, API and R&D
    Last Post: August 14th, 2015, 09:41 AM
  3. Revit 2014 & 2015 wall transparency issue
    By REVITEER32 in forum Structure - General Questions
    Last Post: May 21st, 2014, 05:35 PM
  4. Replies: 0
    Last Post: February 5th, 2013, 04:45 AM
  5. Adding Multiple Balusters In Railing
    Last Post: May 19th, 2011, 05:27 PM
