Results 1 to 7 of 7
Like Tree2Likes
  • 1 Post By Steve_Stafford
Thread: About Coordinate
    September 24, 2018
    2
    06:12 PM
    Question About Coordinate
    Hi everyone, i have a question.
    - In revit, i use property line to specify boundary. But i just have point of coordinate, so i dont know how to import this infomation to revit.
    1st column is point's number, 2nd and 3rd is coordinate X, Y, they represent for N/S and E/W indicator, the last one is length between 2 point.
    so could you guys help me please!
    sorry for my bad english!
    June 21, 2012
    Tours, France
    880
    12:12 PM
    Quote Originally Posted by thai_hoang211095 View Post
    - In revit, i use property line to specify boundary. But i just have coordinate of point, so i dont know how to inport this infomation to revit.
    Sounds to me like you need to acquire coordinates, but without much more info is pretty hard to say, can you post some images, regrds
    September 24, 2018
    2
    06:12 PM
    oh sorry, i posted this with an image,dont know reason why it dissapear, here is it. sorry again.
    with 1st,2nd,3rd and 4th column like i said before.
    Attached Thumbnails Attached Thumbnails About Coordinate-42408249_2193532567325107_1468661863548977152_n.jpg
    Mr. Revit OpEd
    2,785
    03:12 AM
    Less Clever - sketch the boundary in AutoCAD using the coordinates. Import DWG into Revit and sketch the property boundary over it.
    More Clevererer - Use Dynamo to sketch out the boundary based on the list of coordinates. I don't know right now if the property boundary element can be created through Dynamo.
    I also considered a toposurface which can be created from coordinates but it's not much use for sketch the property boundary afterward.
    cganiere likes this.
    Mr. Revit OpEd
    2,785
    03:12 AM
    I used this problem as an excuse to dig into Dynamo a bit. I created the attached graph to read a text file with coordinate values, one line per X,Y,Z values. I created a 3D cylinder and model lines to form a target symbol family. The graph places a target family at each coordinate location. In Revit I assigned the Length units to Meter and used the Dynamo graph to generate and place the target families. The last step was to sketch the property boundary segments from target to target.
    It was necessary to move the points closer to Revit's origin so they were not so far away, Revit hates that. After doing that, I moved the Survey Point (not clipped) to one corner of the property (target family location) and then used Specify Coordinates at Point at that location using the coordinate values for that corner. This would allow me to export the result to DWG if necessary.
    Attached Thumbnails Attached Thumbnails About Coordinate-propertypoints02.jpg   About Coordinate-propertypoints.jpg
    May 18, 2011
    Calgary, AB
    375
    04:12 AM
    Quote Originally Posted by Steve_Stafford View Post
    Love this. How did you "move the points closer"? I could see dropping the first 3 digits from both the x and y since they are consistently the same in all the points.
    Mr. Revit OpEd
    2,785
    03:12 AM
    Quote Originally Posted by cheinaranta
    ...Love this. How did you "move the points closer"?...
    Very high tech A window selection and Move tool.
    I did that the first time when I got an error about the Geometry Working Range in Dynamo. After I changed it to Extra Large I could just use the full values. I don't recall many coordinates being so consistent on other projects, maybe because of imperial units here in the USA? Then again I don't really look at all the coordinates like this usually. More often it is just bearing and distance and one or two coordinates for checking purposes.
    cheinaranta likes this.
  1. Spot coordinate origin
    By Idunno in forum Architecture and General Revit Questions
    Last Post: June 6th, 2017, 06:02 PM
  2. texture coordinate
    By p3d in forum Architecture and General Revit Questions
    Last Post: August 1st, 2015, 02:05 AM
  3. Coordinate Issues
    By Saldambro in forum Architecture and General Revit Questions
    Last Post: June 26th, 2015, 12:53 AM
  4. (CAD) Coordinate Confusion
    Last Post: May 23rd, 2011, 05:20 PM
