Results 1 to 5 of 5
Thread: Reconstruction: Phases and Rooms
    May 26, 2011
    31
    12:29 PM
    Hello,
    I'd like use phases in Revit for documentation of reconstruction. In our county is typicall do 3 types of drawings:
    1. CS= Current State ... Initial state of building
    2. DS = Demolition State ... State where is CS and highlit construction for demolition
    3. NS = New State ... View to state after demolition and new costruction to build.
    My problem is, how to set up phases to view room from CS in DS, please?
    Thanks for replies and tips
    Administrator Ian.Kidston's Avatar
    Melbourne, Australia
    1,144
    11:29 PM
    Hi PepaR
    To achieve what you are after, the phase filters would be set as:
    CS - Existing (Show All)
    DS - New Construction (Show previous + demo)
    NS - New Construction (Show Complete)
    Cheers,
    May 26, 2011
    31
    12:29 PM
    Thanks for tip. So, I did it and rooms is still not displayed in DS (see file please and view 02 1 NP DS).
    Attached Files Attached Files
    "Mark Twain"
    mdradvies's Avatar
    December 16, 2010
    Boxtel, Netherlands
    4,551
    12:29 PM
    That's because Rooms are Phase specific. You cannot show them in other Phases.
    You can do one of these things:
    1. Create a Duplicate View of 01 1NP.CS, Hide everything but the Rooms and use as an overlay on your sheets on top of 02 1.NP.DS
    2. Remove the Demolished Phase and start working with Phase Filters. Create a New Phase Filter which shows Demolished objects as normal and another which shows Demolished objects as Demolished. Although this brings up the problem of Rooms not being defined properly... So you'll need to place some Room Separation Lines there.
    See attached.
    May 26, 2011
    31
    12:29 PM
    Great, thanks a lot for kick-off
  1. Not Placed - Rooms
    By retroface in forum Architecture and General Revit Questions
    Last Post: July 12th, 2018, 02:19 PM
  2. Rooms suddenly unenclosed
    By jb0096 in forum Architecture and General Revit Questions
    Last Post: March 24th, 2016, 11:17 AM
  3. Famille électricité 2 phases ou 3 phases
    By amigost in forum MEP - Family Creation
    Last Post: May 15th, 2011, 12:26 PM
  4. Rooms in Groups - Error
    By LKeyser in forum Architecture and General Revit Questions
    Last Post: February 24th, 2011, 09:11 PM
