Page 3 of 8 FirstFirst 1234567 ... LastLast
Results 21 to 30 of 74
Like Tree43Likes
Thread: Revit Icons (for those of you not on Twitter)
  1. #21
    June 21, 2012
    Tours, France
    937
    04:02 AM
    Thanks a lot @Aaron, I've already installed the icons and they look great, I pretty easy in WIN 10 by selecting the Icon and by hitting in the properties button you'll find the "Change icon" option!!, regards
  2. #22
    Gold Coast
    2,602
    12:02 PM
    Quote Originally Posted by GMcDowellJr View Post
    Most of the icons in my task bar are blank. No idea why. Annoying as hell.
    for me it was also happening on the desktop and it was only the new revit ones going blank. weird.
  3. #23
    Rotterdam, South Holland
    3,042
    04:02 AM
    You guys with blank icons, what OS are you on, and where is the ICO file stored? Windows 8.0/.1 had some odd/crappy behavior with regards to icons that don't live in the EXE.
    I hope to do some extensive testing of @DaveP's solution in various versions and builds of OS's. Mostly because every new version of Windows 10 ***** up/breaks something new.
  4. #24
    10,036
    09:02 PM
    It may depend on where you have saved them, as to whether or not they have gone blank at startup, or not. Mine are in the root of C, (in a folder) but not under the User Profiles, or the Program Files, or a network location. No issues with them blanking out, that ive noticed. Either in the start menu or the Taskbar/QuickLaunch. Ive actually been replacing other icons in the same fashion, for a few years now, without issue.
    But its easy to accidentally have them blank out (and stay blanked out) if you have the ICO pathed to a resource that isnt always present.
  5. #25
    Moderator cellophane's Avatar
    August 9, 2011
    Louisville, KY
    6,104
    10:02 PM
    Quote Originally Posted by Gordon Price View Post
    I've noticed the icons going blank after installing updates with some software (I'm on Win 8.1). Easiest fix I know of is to unpin it, then re-pin it on the task bar.
  6. #26
    Moderator DaveP's Avatar
    January 10, 2011
    St Paul, MN
    2,949
    09:02 PM
    Quote Originally Posted by PatrickGSR94 View Post
    dang, don't people remember what icons are where?
    Not me!
    I support about 85 people & I'm not going to remember everybody's desktop layout!
    BTW; Here's a Tip/Trick I use when I sit down at one of those people who've got 95 files on their desktop.
    Click on any icon on the desktop, and then type the first character of the program name. An icon that starts with that character will highlight. Keep typing that character, and Windows will cycle through, for example, all of the "R" icons. Once you get the one you want, hit Enter to run it.
  7. #27
    10,036
    09:02 PM
    LOL, if someone calls me over for help, and Revit isn't even opened, i'm leaving. Ill come back when they have the project opened.
  8. #28
    January 10, 2011
    St Paul, MN
    2,949
    09:02 PM
    I usually get the opposite.
    I need to install an update, and they're out of the office with Revit still running & a model open.
    Then I go to close it & find out they haven't SWC'd for an hour.
    Or, they've got a Windows update pending (usually for a couple of days) and I can't install my update until Windows does.
    Twiceroadsfool likes this.
  9. #29
    Mr. Revit OpEd
    2,861
    07:02 PM
    Quote Originally Posted by DaveP
    ...I need to install an update, and they're out of the office with Revit still running & a model open. Then I go to close it & find out they haven't SWC'd for an hour. Or, they've got a Windows update pending (usually for a couple of days) and I can't install my update until Windows does.
    Then you'll get complaints Revit crashed and they lost work...
  10. #30
    July 10, 2015
    Boise, Idaho
    641
    08:02 PM
    My rule is if you're going to leave your desk for longer than 2 minutes you must sync. If you're leaving the building for even only 10 seconds, sync. I've seen people step outside for a moment and vanished for an hour because a bird pooped on their shirt. Never leave without syncing. That should be common sense.
    GMcDowellJr likes this.
  1. Help with tiny icons in revit 2016
    By n8lloyd in forum Architecture and General Revit Questions
    Last Post: August 13th, 2016, 05:52 PM
  2. Revit OpEd: Loaded and Unloaded Link Icons
    Last Post: August 2nd, 2013, 03:15 PM
  3. Replies: 0
    Last Post: August 6th, 2012, 11:15 AM
  4. What Revit Wants: M-SIX on Twitter
    By luke.johnson in forum Blog Feeds
    Last Post: November 14th, 2011, 02:15 AM
  5. Replies: 0
    Last Post: July 13th, 2011, 11:11 PM
