Results 1 to 3 of 3
Thread: Print to Pdf problem
    July 26, 2018
    15
    06:14 AM
    i'm trying to make pdfs of my sheets but after selecting selected sheets & views I can't select that "select" to decide my sheets! Help me
    Thanks
    Senior Member biff's Avatar
    June 13, 2011
    Australia
    818
    12:14 PM
    Try saving closing opening project. Which pdf printer are you using?
    September 14, 2018
    Rotterdam
    2
    02:14 AM
    If that does not work, try to set your PDF printer as a default in Windows.
    Configuration > Printers > Uncheck 'let Windows decide' and choose PDF printer as default under manage
  1. Print to PDF
    By MachoMan in forum Architecture and General Revit Questions
    Last Post: February 23rd, 2018, 04:46 PM
  2. print from dwf
    By Giladham in forum Architecture and General Revit Questions
    Last Post: November 11th, 2015, 08:26 AM
  3. Print SetUp won't show "Print to PDF"
    By NicolasMelo in forum Architecture and General Revit Questions
    Last Post: April 26th, 2015, 07:34 AM
  4. Print Visible Portion = Offsetting on the print out
    By sgray05 in forum Architecture and General Revit Questions
    Last Post: January 9th, 2015, 06:54 AM
  5. Can't print DWF (but can print anything else)
    By cellophane in forum Hardware and Infrastructure
    Last Post: July 31st, 2012, 02:10 PM
