Results 1 to 3 of 3
Thread: Wall tags not showing up on Prints
    August 27, 2018
    5
    06:48 PM
    Hello revit users,
    This has been driving me up the wall-
    the wall tags aren't showing on my pdf's.
    It appears to be completely random, I've tried un checking the show unreference views parameter, sometimes it works sometimes it doesn't. Maybe it has to do with that?
    It's only the wall tags that aren't printing which is a bit of a mystery to me.
    Has anyone else had this problem, i'm sure it's an easy fix.
    Thanks guys!
    Member d.stairmand's Avatar
    February 24, 2011
    Auckland
    341
    06:48 AM
    Yep - Had this problem, but for Keynote Tags in Plan Views that were Wall Hosted
    Solution - Na not yet. we tried printing to raster, and that worked intermittently
    Member PatrickGSR94's Avatar
    July 7, 2017
    Hernando, MS
    442
    01:48 PM
    Show/Hide unreferenced views refers only to view references like sections and elevations. If you set them to hide, then any view not on a sheet will have its section or elevation mark hidden when printing. That doesn't affect tags.
  1. Room Tags not showing up in Callouts
    By Lox in forum Architecture and General Revit Questions
    Last Post: July 9th, 2015, 09:01 PM
  2. Fonts in PDF prints showing up as boxes......only from Revit
    By ecraider in forum Architecture and General Revit Questions
    Last Post: March 4th, 2015, 03:12 PM
  3. Callout tags not showing
    By jeeenyuss in forum Architecture and General Revit Questions
    Last Post: March 5th, 2014, 11:17 PM
  4. Linked AutoCAD hatch patterns not showing up in Revit prints...
    By kcaparella in forum Architecture and General Revit Questions
    Last Post: January 18th, 2013, 08:54 PM
  5. Surface Transparency- prints correctly but not showing in view
    By mem in forum Architecture and General Revit Questions
    Last Post: November 14th, 2012, 10:40 PM
