Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Like Tree18Likes
Thread: Bricks sticking out
    July 7, 2011
    Rotterdam, Holland
    1,169
    10:42 PM
    Bricks sticking out
    It doesn't happen to often, but I think I blew up Revit. So I guess I need to go look for a better way. Any idea on how to have masonry with bricks in the pattern as in the image below sticking out about 2cm from the rest? Would like to see what shadow does to it.
    Or did I just ran into the limitations of my workstation on a small 15x6 meter house?
    10,036
    03:42 PM
    If you want to troubleshoot whether its the model or the computer, send me the model and ill check it on this end (and then delete it). But it LOOKS like the Anti aliasing is just wigging out. My guess is not enough GPU?
    July 7, 2011
    Rotterdam, Holland
    1,169
    10:42 PM
    OH that image is from the architect and not Revit (well the black and white in the background is my model and she drew over it)
    Got a GTX770 with 2GB memory so that should be OK (old workstation, need to replace that).
    But I'll try again and see if it crashes again or that it for some reason was something weird that time.
    What would be your way to have all those bricks sticking out Aaron?
    I did a thin wall with edit profile, but it seems Revit (or my workstation) does not like that, so maybe face based GM's?
    10,036
    03:42 PM
    Face Based Families would have been my go to method. I do all of my Brick detailing that way. Or unhosted with Voids. But for that, id do face based.
    July 7, 2011
    Rotterdam, Holland
    1,169
    10:42 PM
    Tried the edit profile again and this time it did work, but I had to have more patience than I had the first time around. and that's for 1 out of 4 facades, so will give the Face Based Family a go as well.
    July 7, 2011
    Rotterdam, Holland
    1,169
    10:42 PM
    and would you do just the bit sticking out of the wall or the entire brick with a void to cut it out of the wall as well?
    10,036
    03:42 PM
    I would absolutely have the void cut out the entire real brick depth, then have the solid as the correct sized brick, protruding out. That way its correct in details, as well.
    Obviously youve already addressed the nominal vs actual discussion, which comes up whenever someone wants to model articulation like this. Good stuff!
    Robin Deurloo likes this.
    July 7, 2011
    Rotterdam, Holland
    1,169
    10:42 PM
    Why is this stuff so fun to do, I was planning to quit working about 3 hours ago.
    It even works in my texture, which still needs some work, because there are some issues with the brick sticking out at the corner for example.
    And still need to talk with the architect on where the pattern should start and that kind of stuff.
    Attached Thumbnails Attached Thumbnails Bricks sticking out-shelpenkade-3d-view-1.jpg
    May 18, 2011
    Calgary, AB
    383
    02:42 PM
    Love masonry work beyond the norm.
    So is it patterned on all 4 sides? I could see those corner outies driving how the pattern starts on the return side.
    July 7, 2011
    Rotterdam, Holland
    1,169
    10:42 PM
    Yep on all 4 sides and indeed we (the architect and myself) need to look into what happens around the corner. I already suggested that maybe we need to keep the pattern away from the corner, because I think it will actually look weird with the brick sticking out even if it is possible without ending up with strange sizes of brick for example. Same goes for around the windows AND the pattern is not nicely centred between the windows now either, so may need to move the windows around a bit to make that fit better.
  1. Saved Viewpoints not sticking
    By Drew in forum Coordination Tools
    Last Post: March 15th, 2016, 08:29 PM
  2. Railing Supports - Types changed per Instance not Sticking
    By GMcDowellJr in forum Architecture and General Revit Questions
    Last Post: November 18th, 2015, 02:37 AM
  3. Reveal on brick wall - makes bricks thinner?
    By LarsBjoern in forum Architecture and General Revit Questions
    Last Post: July 2nd, 2013, 09:04 AM
  4. BIM Troublemaker: Making trouble with bricks
    By BIM Troublemaker in forum Blog Feeds
    Last Post: September 12th, 2012, 09:15 AM
  5. How to model bricks/blocks with pcs parameter
    By bangobeat in forum Architecture and General Revit Questions
    Last Post: September 6th, 2011, 02:19 PM
