Results 1 to 5 of 5
Like Tree1Likes
  • 1 Post By Robin Deurloo
Thread: What is the best way to model this type of wall?
    April 12, 2015
    51
    11:38 AM
    Hi, I'd like to know what's the best way to do this type of wall. I used stacked wall, but when it comes to staircase, it doesn't work.
    As there are many these type of wall in the entire building, I'd like to have it as light-weight in file size as possible. Thanks in advance.
    Attached Thumbnails Attached Thumbnails What is the best way to model this type of wall?-wall.jpg
    Forum Addict Robin Deurloo's Avatar
    July 7, 2011
    Rotterdam, Holland
    1,058
    12:38 PM
    I would do a wall and a wall sweep
    tidalwave1 likes this.
    July 21, 2018
    26
    10:38 PM
    My initial thought was a rail with a "T" profile for railing/top rail family, to save having to edit the profiles of walls all over the place, but a quick test results in some pretty undesirable joins/junctions. Maybe an "l" profile for the railing and then sweep picking 3D edges for the top lip? (Could join a couple of different sweeps in order to get the junction seen in the foreground of photo 1.) Depends on your patience levels with Revit rails I guess
    June 21, 2012
    Tours, France
    879
    12:38 PM
    Quote Originally Posted by tiangtiang View Post
    As Robin already said you can model it as a wall and a wall sweep, and a second workaround is possibly by modeling it as a railing with two profiles, that will do the task more easy for multiple stairs, but as a drawback you need to consider the quantities, HTH
    April 12, 2015
    51
    11:38 AM
    thank you everyone for taking time to respond. I'll use the wall and wall sweep method.
  1. Using a Curtain Wall type as a panel nested in a different type of curtain wall
    By itisntmakingsense in forum Architecture and General Revit Questions
    Last Post: December 12th, 2016, 11:09 PM
  2. (Wall edit type error) can't insert air and thermal layer to the wall
    By leeway180 in forum Architecture and General Revit Questions
    Last Post: September 8th, 2016, 06:34 AM
  3. Wall Type Component List/Legend from the Model?
    By Jj Mac in forum Architecture and General Revit Questions
    Last Post: June 16th, 2015, 03:44 PM
  4. Schedule Door Type to Wall Type
    Last Post: January 12th, 2014, 08:28 AM
  5. Wall types will not display solid fill, strange wall type, and more
    By tweg in forum Architecture and General Revit Questions
    Last Post: December 1st, 2011, 07:56 PM
