Results 1 to 2 of 2
Thread: Wall sweep don't cut the door frame
    October 16, 2016
    391
    11:08 AM
    Hello all,
    As you can see in the images the wall sweep overlap the frame of the door (image 1). If I go to the door family and extend the opening cut until the frame..the result that I have in the floor plan isn't correct (image 2).
    Any idea?
    Thank you in advance!
    Attached Thumbnails Attached Thumbnails Wall sweep don't cut the door frame-image-1.png   Wall sweep don't cut the door frame-image-2.png
    December 20, 2010
    1,028
    05:08 AM
    You have to build a frame to your door family as you would have in real life, then all is well or at least close to it.
  1. Door Frame with Transom - Glazing Showing in Plan
    By LKeyser in forum Architecture - Family Creation
    Last Post: March 1st, 2017, 05:59 PM
  2. Legend & Shedule of Door Frame
    By lallanji in forum Architecture - Family Creation
    Last Post: April 3rd, 2014, 06:53 PM
  3. Baseboard Automatic Cut by Door Frame?
    By Inthemood in forum Architecture and General Revit Questions
    Last Post: June 3rd, 2013, 01:55 PM
  4. window frame sweep wall adjustment
    By nikkiyoung in forum Architecture - Family Creation
    Last Post: October 16th, 2012, 06:38 PM
  5. Sweep frame window on curvy path ?!!
    Last Post: October 25th, 2011, 05:24 PM
