Results 1 to 6 of 6
Like Tree3Likes
  • 1 Post By DaveP
  • 2 Post By DaveP
Thread: Weird dimension changing
    October 16, 2016
    391
    12:34 PM
    Hello all
    I have create the walls in my model in specific dimensions from the interior to interior. Sometimes in Revit when I move a wall which normally souldn't affect the dimension between two others walls, the dimension changed.
    Well I don't know how to describe it better.
    Does happen something similar to you?
    Moderator DaveP's Avatar
    January 10, 2011
    St Paul, MN
    2,842
    05:34 AM
    Dimensions in Revit are between two specific elements.
    Moving other elements (not the two the dimension references) shouldn't affect them.
    UNLESS you have somehow locked a relationship between elements.
    In general, its a bad idea to lock anything (Dimensions or Alignments) in a project.
    MAYBE you can lock dimensions between Grids or something simple like the distance from a Door to a corner, but you'll soon find that locking things in a project starts causing problems like you're seeing.
    MARIA1993 likes this.
    October 16, 2016
    391
    12:34 PM
    Yes, The truth is that I have locked some walls using the align tool..
    Is there any way to unlock them? I cannot find an icon or something.
    Thank you!
    Senior Member Charles Karl's Avatar
    December 6, 2011
    Fairbanks, Alaska
    962
    02:34 AM
    The quick workaround is to copy the wall and delete the original.
    January 10, 2011
    St Paul, MN
    2,842
    05:34 AM
    Quick, perhaps, but deleting things can have even more repercussions than locking.
    Copy to Clipboard might work, but you'd still have to recreate EVERY dimension involving that Wall (and EVERYTHING Hosted by it) in EVERY View.
    Better to use the "Reveal Constraints" tool to find out what's really locked
    JeffH and MARIA1993 like this.
    9,775
    05:34 AM
    If youve aligned and locked a wall to another reference, when you select the wall there IS a padlock visible. Its just faint, and a terrible color, so you can barely see if unless you go hunting for it.
  1. Dimension strings not adding up to the total length dimension string (2017)
    By ledgewood33 in forum Architecture and General Revit Questions
    Last Post: March 26th, 2018, 03:24 PM
  2. Dimensions: Dimension Movement , Dimension Breaks
    By Usernumerouno in forum Architecture and General Revit Questions
    Last Post: October 7th, 2015, 08:15 PM
  3. Dimension & Dimension Text Colours
    By Kristjan in forum Architecture and General Revit Questions
    Last Post: February 11th, 2015, 07:21 PM
  4. temporary dimension (dimension snap) remains large and off screen when zooming in
    By birdnehru in forum Architecture and General Revit Questions
    Last Post: October 27th, 2011, 06:25 PM
  5. Changing the color of dimension lines
    By W.Neuok in forum Architecture and General Revit Questions
    Last Post: December 21st, 2010, 04:24 PM
