Results 1 to 8 of 8
Like Tree2Likes
  • 1 Post By MARIA1993
Thread: Wall multi-layer representation
    October 16, 2016
    391
    11:43 AM
    Hello all,
    In my project I want to create some walls that will have 3layers: Beton/Isolation/sandwich pannel (See the attachment below).
    When this wall is cutted (floor plans/sections) I want to have:
    • green colour for the beton
    • Bleu for isolation
    • grey for the panel
    I thought about the filters, but I cannot find a 'Filter by' category for each layer that itr will give me the result that I need.
    The other thought is to the cut pattern of each material.
    Is someone that can tell me the correct workflow?
    Thank you in advance!
    Attached Thumbnails Attached Thumbnails Wall multi-layer representation-layers.png
    WelcomeToAccord likes this.
    May 18, 2011
    Calgary, AB
    375
    03:43 AM
    Filter would be the obvious better choice, but you can't use them that way.
    Set the colour in the cut pattern of each material.
    October 16, 2016
    391
    11:43 AM
    Quote Originally Posted by cheinaranta View Post
    Thank you for your answer.. is there any way in this structure to use the filters?
    May 18, 2011
    Calgary, AB
    375
    03:43 AM
    Filters only work on categories... so it's the whole wall or nothing. You can't dig down into the layers of the wall using filters.
    October 16, 2016
    391
    11:43 AM
    Ok I chanced the colour in cut pattern.
    Is there any way to control also the thickness of the line for each layer?
    For example beton:0.30
    Isolation 0.25
    Thank you!
    May 21, 2018
    6
    05:43 AM
    Quote Originally Posted by MARIA1993 View Post
    Isolation 0.25
    Thank you!
    I did a quick search and found this thread. Might be useful.
    https://www.revitforum.org/architect...djustment.html
    May 18, 2011
    Calgary, AB
    375
    03:43 AM
    You can adjust the sub category in the walls category called common edges - but that's for every edge in an assembly. I don't believe there is a way to pick an edge an assign a specific line weight to it. That would make a lot of people pretty happy.
    July 17, 2018
    4
    10:43 AM
    I finally got you, i was searching for this, great post, good work, very informative and appreciated poet, keep doing such work...
  1. (Wall edit type error) can't insert air and thermal layer to the wall
    By leeway180 in forum Architecture and General Revit Questions
    Last Post: September 8th, 2016, 06:34 AM
  2. Face Based / Wall Based Voids Disrupt Wall Layer Thickness
    By Limbatus in forum Architecture - Family Creation
    Last Post: April 19th, 2016, 05:13 PM
  3. Wall with 4 layer
    By madism in forum Structure - General Questions
    Last Post: February 23rd, 2016, 04:55 PM
  4. View representation of cut wall in plan
    By DesignApparatus in forum Architecture and General Revit Questions
    Last Post: October 18th, 2013, 12:06 AM
  5. Two Materials different Heights appearance of same Layer on one wall
    By pplusd mikef in forum Architecture and General Revit Questions
    Last Post: April 18th, 2013, 09:44 PM
