Results 1 to 2 of 2
Thread: Copy/monitoring levels, grids and scope boxes and creating floor plans
    Lurker
    January 25, 2018
    2
    07:01 PM
    Question Copy/monitoring levels, grids and scope boxes and creating floor plans
    Hi all, I am in a pickle!
    I am working on a project that is comprised by 7 buildings (each on its own individual model), a site model and an annotation model where I plan to create the drawing set.(All is being done in Revit 2018) All buildings and site model have been linked into the annotation model. We set the shared coordinates so when linking all individual models into the annotation model, they came right into place. Each building has a different pad elevation, and I need to create floor plans for each building (and all buildings have different level 1's b/c of the sloping site). I am trying to copy monitor the scope boxes, grids and levels from each building model into the annotation model but I am not able to. My annotation model doesn't display the scope box even though it is turned on in the view template. I didn't set all grids and levels to match the extents of the scope box yet, I think I should do that once I have been able to copy monitor them into the annotation model.
    Any help would be much appreciated!
    Thank you very much!
    Coeur d Alene, ID
    4,558
    06:01 PM
    Use the site model for your drawing index sheets....use each individual building model for annotation. For the stress of trying to have all sheets in one model and not being able to have duplicates and using all the workarounds it would be easier to keep it in each building.
  1. Grids and Scope Boxes
    Last Post: May 18th, 2015, 10:10 PM
  2. Grids, views and scope boxes
    Last Post: March 30th, 2015, 06:32 PM
  3. Replies: 0
    Last Post: June 23rd, 2014, 06:45 AM
  4. Replies: 0
    Last Post: May 22nd, 2014, 12:15 AM
  5. Grids, Scope boxes and Linked models
    By DaveP in forum Architecture and General Revit Questions
    Last Post: April 4th, 2013, 09:22 PM
