Results 1 to 5 of 5
Thread: formula angle
    May 19, 2012
    75
    12:21 PM
    formula angle
    Hello,
    I want to make a formula which can link the dimensions of the angle together. But how can I do this?
    kind regard,
    peter smith
    jmk
    jmk is offline
    Forum Addict jmk's Avatar
    December 31, 2012
    NM, USA
    1,385
    04:21 AM
    You can't use ampersands, and only text requires quotes. And is used for logic. To add the angles you would use the plus sign:
    d1+d2+d
    I suggest you review this thread: https://www.revitforum.org/tutorials...day-usage.html
    May 19, 2012
    75
    12:21 PM
    I mean a L-shaped corner profile. I often call an angle. it isn't a degree of an angle . Sorry for the mistake.
    With these info ("d" and "d1" en "d2") I want to make formula which can form a dimension of a corner profile: L160x80x2
    How can I do this?
    jmk
    jmk is offline
    December 31, 2012
    NM, USA
    1,385
    04:21 AM
    Ah, that is different. You can't convert parameters to text values. You can do it in a project schedule (if they are shared parameters) with a combined parameter, or you can use dynamo to create that combination and push it back to the family, but you would need to run it each time you make a change.
    Mr. Revit OpEd
    2,785
    03:21 AM
    That's the purpose and function of family types. Define the size with a name and enter the appropriate matching values in the corresponding parameters.
  1. Angle between lines?
    By ryntau in forum Dynamo BIM
    Last Post: March 2nd, 2018, 07:48 PM
  2. Replies: 2
    Last Post: November 18th, 2016, 02:24 PM
  3. Hatching at an Angle
    By JasonNelson92 in forum Architecture and General Revit Questions
    Last Post: September 20th, 2016, 02:44 PM
  4. Shadows at 45 angle
    By piper76 in forum Architecture and General Revit Questions
    Last Post: September 19th, 2016, 06:42 PM
  5. Schedule formula (is there a formula expert in the house?)
    By John McCamont in forum Architecture and General Revit Questions
    Last Post: September 9th, 2011, 09:50 PM
