Page 1 of 2 12 LastLast
Results 1 to 10 of 18
Like Tree4Likes
Thread: Edit Room Boundary
    November 2, 2017
    San Diego, California
    73
    02:46 AM
    Edit Room Boundary
    I am trying to do what i *think* should be a simple task, just edit the room boundary to adjust to the extents of the room, but i am stumped. when i click on the room i don't get any thing prompting me to edit the boundary. Please any help greatly appreciated !!! See attached image !
    Attached Thumbnails Attached Thumbnails Edit Room Boundary-room-boundary-question.jpg
    June 10, 2012
    19
    10:46 AM
    Hi!
    Is your problem the room doesn’t follow when you move the Wall?
    If so, I would look for a hidden room separation line located at the wall’s previous location. Otherwise this looks quite strange.
    Skickat från min iPhone med Tapatalk
    jmk
    jmk is offline
    Forum Addict jmk's Avatar
    December 31, 2012
    NM, USA
    1,385
    03:46 AM
    You can also check for a higher wall (like a soffit) that is set to be room bounding and could be affecting the shape. Double check that you don't have a plan region in the view. Try cutting a section to see if you get ideas. Do you have any linked models? Double check them for room bounding lines. Review any turned off worksets that could have something room bounding in them. Is anything in design options? I've seen this in cases where the room is in the main model, but the walls are in options.
    July 10, 2015
    Boise, Idaho
    591
    03:46 AM
    Did somebody edit the profile of a wall? That's the one that gets my people all the time
    Member aristide's Avatar
    July 11, 2011
    Boston, MA
    74
    05:46 AM
    I think this is a simple case of misunderstanding how Rooms are supposed to work.
    You don't need to select a Room in order to Edit the boundary.
    You move the walls around, and the Room will automatically fill up that space.
    cganiere likes this.
    jmk
    jmk is offline
    December 31, 2012
    NM, USA
    1,385
    03:46 AM
    Quote Originally Posted by aristide View Post
    You are correct, but the room also isn't filling up the space as bounded by the walls, so there looks to be something else affecting the room size.
    St. Louis, MO
    1,954
    04:46 AM
    and to clarify a bit further.....
    -Rooms must be set to Room Bounding for this to work
    -Room Separation Lines, Floors, Roofs and Columns can also be Room Bounding.
    -Linked Models can also be set to be Room Bounding
    Moderator DaveP's Avatar
    January 10, 2011
    St Paul, MN
    2,842
    04:46 AM
    This is where the Selection Box Tool can come in handy.
    Select the Room and, on the Modify tab under View, pick Selection Box. Or type BX
    That will set your default 3D View to the extents of the Room.
    Turn on all Categories and that might help you see what's causing the left side of the Room to get cut off.
    duende123 likes this.
    April 12, 2011
    Chicago, IL
    518
    04:46 AM
    Is there a finish floor in part of the room set to bounding that's above the host level of the room? I've seen some weird things happen when the room is trying to exist in the zero space between a structural floor and finish floor.
    Senior Member biff's Avatar
    June 13, 2011
    Australia
    832
    09:46 PM
    If stumped still after trying above suggestions, could you not delete room and draw the room with room seperation lines to create the room again?
  1. Unable To edit floor boundary
    By robledojuan7 in forum Architecture and General Revit Questions
    Last Post: January 14th, 2016, 06:12 PM
  2. Unable To edit floor boundary
    Last Post: December 15th, 2015, 02:44 PM
  3. Double boundary @ Ceiling edit
    By DaveP in forum Architecture and General Revit Questions
    Last Post: October 22nd, 2015, 08:28 PM
  4. Stair Boundary Edit
    By elizzile in forum Architecture and General Revit Questions
    Last Post: August 28th, 2014, 06:27 PM
  5. Gross area boundary edit
    By gentlepuppies in forum Architecture and General Revit Questions
    Last Post: December 8th, 2012, 06:24 PM
