Results 1 to 5 of 5
Like Tree1Likes
  • 1 Post By Dave Jones
Thread: Revisions tracking
    May 16, 2016
    104
    10:29 AM
    Revisions tracking
    Revit 2018
    I need to send PDF's of a revision and there are probably 30 sheets with revision clouds (out of 60 total) for this particular revision, but it's an older project that has been collecting dust for 8 months or so and the only way I can think of which sheets I should print is by printing them all and going through the PDF and writing them down, then deleting the sheets that are not affected by the revision.
    Does Revit keep track of which sheets have each revision on them?
    May 18, 2011
    Calgary, AB
    375
    03:29 AM
    Quote Originally Posted by DCLowery View Post
    Revit 2018
    It knows only the current revision assigned to the sheet. Should be good enough for your situation.
    "I am NOT a Revit tutor!"
    Dave Jones's Avatar
    4,477
    02:29 AM
    Revit 2018
    sure it does...make a sheet list schedule with the fields Sheet Number and Current Revision and then filter by Current Revision
    edit: and Chris is right, the schedule will give you only the current revision
    cganiere likes this.
    May 16, 2016
    104
    10:29 AM
    Quote Originally Posted by Dave Jones View Post
    Awesome thanks!
    Dave Jones's Avatar
    4,477
    02:29 AM
    Awesome thanks!
    no problem, glad I could help!
  1. Tracking View Changes?
    Last Post: June 27th, 2016, 08:26 PM
  2. Workflow for tracking changes
    By john.warburton in forum Architecture and General Revit Questions
    Last Post: March 26th, 2016, 08:35 PM
  3. Tracking Revisions in Schedules
    By taylor.odell in forum Architecture and General Revit Questions
    Last Post: February 25th, 2016, 03:28 PM
  4. REVISIONS : Gerer des numéros de révisions à double caractère ainsi que "0" !!!
    By guibouvard in forum Tutoriels, trucs et astuces en français
    Last Post: February 24th, 2012, 09:33 PM
  5. List of Revisions vs Individual Revisions
    By Craig Howie in forum Architecture and General Revit Questions
    Last Post: December 15th, 2011, 07:46 PM
