Results 1 to 4 of 4
Thread: Element pinned and unpinned
    May 18, 2011
    Calgary, AB
    375
    04:32 AM
    Question Element pinned and unpinned
    Cleaning up elements on worksets and came across some elements that couldn't be moved to a workset from the properties palette. I tried to copy and paste and it warns me that the element needs to be unpinned. Try to go an unpin it and both pin and unpin are greyed out. I can't delete it, I can't copy and paste, I can't revise the workset, audit has been done recently... I'm stumped.
    Attached Thumbnails Attached Thumbnails Element pinned and unpinned-pin_unpin.jpg
    Mr. Revit OpEd
    2,785
    03:32 AM
    Did you sort this out? It looks like the Make this element Editable icon is visible, click that and then the Pin Icon should appear.
    Edit: Wrong, that's the Group icon my mistake. Perhaps it's objecting to an element in the group?
    Senior Member biff's Avatar
    June 13, 2011
    Australia
    832
    10:32 PM
    Maybe you had select pinned element turned off.
    May 18, 2011
    Calgary, AB
    375
    04:32 AM
    Quote Originally Posted by Steve_Stafford View Post
    Yes. The group was on a different workset (which was closed) but the elements in the group were on the open workset.
    Opened up both worksets, did a copy/paste in place. Everything is happy now.
    Groups are not my forte but getting better.
  1. Unable to select pinned objects
    By kfitz in forum Tutorials, Tips & Tricks
    Last Post: October 31st, 2016, 08:02 PM
  2. Replies: 0
    Last Post: July 21st, 2016, 06:45 PM
  3. Pinned element cannot be selected?
    By drumman in forum MEP - General
    Last Post: September 1st, 2015, 08:06 PM
  4. Replies: 0
    Last Post: December 20th, 2014, 05:15 AM
  5. Shared and Pinned Link Issue
    Last Post: March 7th, 2013, 09:10 PM
