Page 1 of 2 12 LastLast
Results 1 to 10 of 19
Like Tree7Likes
Thread: Concrete and stone wall
    Junior Member Zrinka's Avatar
    February 25, 2017
    15
    12:33 PM
    What is the best way to make wall like in picture? It is concrete with stone finish... What I am most concerned about is how to make stone appear on the top of the wall too.. like on picture
    Poslano sa mog VTR-L09 koristeći Tapatalk
    Forum Addict Robin Deurloo's Avatar
    July 7, 2011
    Rotterdam, Holland
    1,059
    12:33 PM
    I see 4 walls there
    1. concrete
    2. stone on the left side
    3. stone on the right side
    4. stone on top
    Join 2, 3 and 4 and you have your wall
    9,780
    05:33 AM
    I see three walls and a roof, or three walls and a wall sweep. But yeah, same concept as Robin.
    Robin Deurloo likes this.
    June 10, 2012
    19
    11:33 AM
    Would 1 Wall with 3 layers (stone+conc+stone) and a roof work?
    Skickat från min iPhone med Tapatalk
    July 7, 2011
    Rotterdam, Holland
    1,059
    12:33 PM
    It would work, but in my experience and I know also in Aaron's, having walls separated by layer is a better way to do any wall in the long run. But it does depend on the wall. If any of the layers bottom or top constraint are different separate layers is a must for me. But also things like scheduling will work much better with separate walls.
    The scheduling is also the reason why I would do the top bit as a wall instead of a floor too.
    Twiceroadsfool and tidalwave1 like this.
    June 10, 2012
    19
    11:33 AM
    That makes sense
    9,780
    05:33 AM
    Quote Originally Posted by Robin Deurloo View Post
    Certain wall typed I will bundle together as one wall type, like sheathing over metal studs, or brick over air space. But concrete and cmu are always separate and on their own, in my world.
    What Robin says above makes total sense. I defer to wall sweeps or roofs because (typically here) the top of that wall isn't flat, it's sloped.
    But we're splitting hairs.
    Aaron Maller
    Director
    Parallax Team, Inc.
    July 7, 2011
    Rotterdam, Holland
    1,059
    12:33 PM
    yep sheeting over metalstud is 1 wall for me as well and air space I usually don't model.
    The top of the walls have many different ways of being done here, from a brick soldier layer (flat on top like the OP posted) to very intricate pieces of masonry or prefab concrete. So I guess it all depends on the situation, type of wall and info that is needed from all the geometry.
    Good lesson here is to think about stuff first and not go mad modelling as much as possible as fast as possible with the risk of needing to do stuff for a second time.
    February 25, 2017
    15
    12:33 PM
    Thank you guys for all you advice... I will try wall on top, wall on the left and right and another wall on top, join all together and send the photo or the result ;-) soon
    February 25, 2017
    15
    12:33 PM
    Looks all right! Three walls (all three walls not plus a ceiling) joined..upper left and right
  1. old wall stone (3D revit)
    By templario82 in forum Architecture and General Revit Questions
    Last Post: May 19th, 2016, 01:40 PM
  2. Archways and Stone Wrap and Wall Joins
    By ben032401 in forum Architecture and General Revit Questions
    Last Post: August 13th, 2015, 01:56 PM
  3. solid stone wall and coursing
    By deafred in forum Architecture and General Revit Questions
    Last Post: March 20th, 2014, 02:38 PM
  4. Merging concrete column to concrete wall?
    By craiglarkin in forum Structure - General Questions
    Last Post: January 16th, 2013, 04:52 PM
  5. Granite Stone Wall
    By paul_k11 in forum Architecture and General Revit Questions
    Last Post: December 16th, 2011, 02:53 PM
