Page 1 of 2 12 LastLast
Results 1 to 10 of 18
Like Tree2Likes
Thread: Wall join lines visibility
    Junior Member Zrinka's Avatar
    February 25, 2017
    19
    07:05 PM
    Hello... I have a wall that was created by picking multiple arcs one next to the other.. each arc of different radius... I joined those wall segments into one wall.. now I have a problem that in an elevation or in section view, the line where two wall segments join is visible... I want it invisible... I have tried linework tool and I have made it invisible in one of my section views.. but I want it invisible in all views... Is it somehow possible? Or I should create this kind of wall in some other way?
    Poslano sa mog VTR-L09 koristeći Tapatalk
    Gold Coast
    2,602
    04:05 AM
    It's possible if you make the wall in a single arc...or a spline (but don't do that). It'll clean up if you use the fillet arc tool but that will also make another arc at every join, probably not what you're after. Maybe the LW tool when you need it.
    I hear this complaint from our renderers all the time "Revit has too many pieces".
    February 25, 2017
    19
    07:05 PM
    Is it ok to use a new family and to make wall by sweeping the profile along those arcs? instead of picking arcs and making walls made of more arc segments?
    February 25, 2017
    19
    07:05 PM
    Linework is too much work... Besides how do I make the the lines I've made invisible in one section, also appear invisible in another new section???
    Member duende123's Avatar
    November 20, 2015
    186
    02:05 PM
    What you have is a geometric problem.
    You need the union of the curves and the centers of the two arcs to be aligned.
    Otherwise a line will appear in the union.
    like this:
    Attached Thumbnails Attached Thumbnails Wall join lines visibility-acuerdo01.jpg   Wall join lines visibility-acuerdo02.jpg   Wall join lines visibility-acuerdo03.jpg   Wall join lines visibility-acuerdo04.jpg
    February 25, 2017
    19
    07:05 PM
    This is the basis for my wall... No way I can make those centres aligned... Maybe I try to deaw an ellipse instead of this... Can you make a wall by picking an ellipse in Revit?
    January 19, 2012
    322
    01:05 PM
    Yes you can. I've done it all the time.
    November 20, 2015
    186
    02:05 PM
    it seems to me that an elliptical wall can not be made ...
    If you can, resolved.
    If not, try to do what I tell you. It is not easy but it is possible to draw something very close to an ellipse with circumferential arcs.
    Notice that each union is aligned with the centers of the arcs that come together.
    Attached Thumbnails Attached Thumbnails Wall join lines visibility-elipse01.jpg
    February 25, 2017
    19
    07:05 PM
    Quote Originally Posted by duende123 View Post
    like this:
    Hey duende! I took the time to correct my geometry the way you advised... So that the arcs are aligned the way you described! It worked! It's a miracle :-D I would still like to have my geometry any way I want but well maybe it's better to have the geometry a bit more "in order" anyway.. Ty !!!!!
    November 20, 2015
    186
    02:05 PM
    It's like that .... Geometry, like gravity, is always there
    GMcDowellJr and Zrinka like this.
  1. Controling New Section Lines Visibility on other views
    By tiangtiang in forum Architecture and General Revit Questions
    Last Post: January 19th, 2018, 06:47 AM
  2. Trying to join a wall finish to a wall with an opening. Doesnt play nice
    By joewallace in forum Architecture and General Revit Questions
    Last Post: January 12th, 2018, 10:01 PM
  3. Replies: 0
    Last Post: March 10th, 2015, 06:45 AM
  4. Grid Lines Visibility Mystery
    By gonzoniko in forum Architecture and General Revit Questions
    Last Post: February 4th, 2015, 09:46 AM
  5. Topo contour lines visibility
    By Maddren in forum Architecture and General Revit Questions
    Last Post: November 25th, 2013, 06:39 AM
