Page 1 of 2 12 LastLast
Results 1 to 10 of 12
Like Tree1Likes
Thread: Surface pattern goes black
    Member Hirvio's Avatar
    March 8, 2011
    Zagreb, Croatia
    254
    06:55 AM
    I used stone surface pattern from StoneCAD library. Imported pattern looks fine in material editor, but applied on the wall it is OK only when under one zoom ratio:
    If I zoom it in or out it turns dark grey (and unfortunately it prints out the same):
    Any reason for such behavior? Hardware acceleration is off. Detail level is not an issue.
    EDIT: I changed scale while importing pattern from 1 to 2 and now it looks consistent (although bigger then I wanted).
    Anyway, I would like to hear some opinions on this matter.
    St. Louis, MO
    1,954
    11:55 PM
    Seems like a scale issue of the pattern? Does it look correct at different scales/in views?
    Is it a drafting or model pattern?
    It could be a hardware acc./graphics card issue.
    As far as printing black,try setting it to Raster instead of Vector in the print settings.
    March 8, 2011
    Zagreb, Croatia
    254
    06:55 AM
    Quote Originally Posted by cliff collins View Post
    Model.
    Raster printing was already turned on and hardware acc. was off.
    I edited my post (see above). It is definitely a scale issue. It would be logical that it goes black when I zoom out, because it is too dense to show, but I don't see much logic why it shows correctly only on one zoom notch between zoom in and zoom out.
    10,362
    11:55 PM
    Thats just how hatch is, in Revit. It picks a certain zoom level to show correctly, and it stinks at any level farther away than that, LOL.
    M_cubed likes this.
    St. Louis, MO
    1,954
    11:55 PM
    Still doesn't explain the printing problem.....................
    United States
    1,640
    09:55 PM
    This is a common problem with those very complicated patterns, particularly the stone patterns, e.g. StoneCAD, etc. I don't know of any solution other than what you did (increase import scale).
    Quote Originally Posted by Hirvio View Post
    10,362
    11:55 PM
    Sure it does. It prints them that way if it *decides* theyre too dense. Ive even seen wackiness once or twice where i split a wall, and in a perspective view the *closer* portion had the hatch, and the *farther* portion turned to solid color. Annoying as all heck. But that was back in 2010, so i know its been that way a while.
    St. Louis, MO
    1,954
    11:55 PM
    I've seen the fill pattern going grey or black on screen, depending on level of zoom before--but we have always gotten it to print correctly, so from our experience there's a difference in a "display problem" and a "printing problem" in situations like this.
    10,362
    11:55 PM
    Ok. Ive seen it happen simultaneously on screen and printing, in the same views, with the same objects, at the same time. So in our experience its the same problem.
    St. Louis, MO
    1,954
    11:55 PM
    So what did you do about the printing problem? Did you change the pattern?
  1. Surface Pattern for Topography
    By JCM in forum Architecture and General Revit Questions
    Last Post: February 3rd, 2012, 03:10 AM
  2. Screen goes black!!!!
    By wjnaim in forum Architecture and General Revit Questions
    Last Post: September 19th, 2011, 02:54 PM
  3. wall surface pattern
    By mno in forum Architecture and General Revit Questions
    Last Post: September 9th, 2011, 02:16 PM
  4. Roof surface pattern, where i can change line weight?
    By bangobeat in forum Architecture and General Revit Questions
    Last Post: June 15th, 2011, 11:51 PM
  5. Family Surface Pattern Thickness
    By W.Neuok in forum MEP - General
    Last Post: June 1st, 2011, 08:02 PM
