Results 1 to 10 of 10
Thread: Rake board
    February 9, 2018
    Va Beach, VA
    59
    01:03 AM
    Rake board
    I have always had trouble setting 6" rake boards on 8" roofs
    As you can see here, it really shows.
    Does anyone know how to allow the rake or "Box cornice", to show smaller than, say, a 10" rafter roof system?
    Thanks!
    St. Louis, MO
    1,952
    07:03 PM
    Are you using the Fascia Tool--with a Profile family?
    Member BLothian's Avatar
    December 11, 2013
    Livingston, Scotland
    464
    01:03 AM
    I'm not sure I really understand the question, can you make it a little clearer what the issue is?
    February 9, 2018
    Va Beach, VA
    59
    01:03 AM
    That picture shows an 8" gable roof with a 10" shed roof coming into it.
    That is a 8" Fascia used. As you can see, the 8" fascia doesn't even cover the 8" roof, much less the 10"
    Often times, I try to not even use fascias because of this, but here, I would like to somehow (in 3D) show a smooth transition. I think I could by joining the fascias with join tool after I set them up properly.
    We, often times only use 6" fascias and rakes (and box cornices) in this part of the world.
    Thanks!
    St. Louis, MO
    1,952
    07:03 PM
    You can use a Generic Model for this. Model-in place is one way, you can get exactly the dimensions/shape you need.
    Member kowen1208's Avatar
    January 18, 2013
    Utah
    354
    07:03 PM
    If I understand correctly, part of your problem is the fascia covering the rake completely. This comes down to modeling the roof and fascia how they'll be built. Do the rakes and eaves need to be the same thickness as the structure, or can 4" or 6" outlookers be used?
    February 9, 2018
    Va Beach, VA
    59
    01:03 AM
    Yes, "Lookouts" can and would be used in real life.
    But im not sure how to model it.
    I think I will build my roof out of 2x6s and set it up like it would be 2x8s.
    Moderator cellophane's Avatar
    August 9, 2011
    Louisville, KY
    5,999
    08:03 PM
    When you say 8" Gable Roof, is that an 8/12 pitch, or an 8" thick roof assembly?
    That aside, if you place your fascia in one pass, or add additional segments to an existing fascia your 3D & elevation joins between the different pitches should cleanup without any issues.
    February 9, 2018
    Va Beach, VA
    59
    01:03 AM
    I mean an 8" roof Assembly.
    And yes, I do find that when you place all the fascia, it does clean up nicely.
    Thanks for all the help! I'll get through this by learning a little bit and go on to another procedure where, hopefully I'll learn a little bit Thanks again!
    January 18, 2013
    Utah
    354
    07:03 PM
    Quote Originally Posted by glkirk View Post
    In cases like this, I do two roofs:
    The first roof has the correct structural depth and has no overhang.
    The second roof has the the depth of the outlookers and has an overhang.
    Then line them up to the proper height and join their geometry (first pick should be the structural roof, then the outlookers).
    I use this whenever I have a project with a pitched roof that uses TJIs or something similar for the roof framing.
  1. Rake fascia
    By glkirk in forum Architecture and General Revit Questions
    Last Post: March 29th, 2018, 06:47 AM
  2. Bat & board siding
    By kroke71 in forum Architecture and General Revit Questions
    Last Post: July 21st, 2014, 11:59 PM
  3. rake curtainwall mullion joinery
    By Anondrafter in forum Architecture and General Revit Questions
    Last Post: November 9th, 2012, 01:51 AM
  4. Eaves Board
    By theshell07 in forum Architecture and General Revit Questions
    Last Post: April 27th, 2012, 04:20 PM
  5. Trim 1x12 rake on a gable?
    By wjnaim in forum Architecture and General Revit Questions
    Last Post: June 20th, 2011, 12:28 AM
