Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Like Tree8Likes
Thread: Grid cleanup
    May 16, 2016
    104
    06:04 AM
    Grid cleanup
    Revit 2018
    When I copy/monitor the grids from the linked Architectural model, they come in all bunched up as in the first image. So I clean them up as in the second image. No problem. But I have to do this for each floor. Is there a way to copy them to other levels in their fixed-up state?
    Attached Thumbnails Attached Thumbnails Grid cleanup-grids.jpg   Grid cleanup-grids-2.jpg
    December 8, 2010
    Long Beach, CA
    196
    11:04 PM
    "Propogate Extents" should take care of that for you.
    Jon
    "I am NOT a Revit tutor!"
    Dave Jones's Avatar
    4,479
    11:04 PM
    Quote Originally Posted by kingjosiah View Post
    Jon
    I wish it were true but I don't think that Propogate Extents will offset the grid heads in each view and I believe that's what the OP is after. I wonder if this is something that Dynamo could do? It is a royal PITA when one has a multi story building...
    9,874
    01:04 AM
    Quote Originally Posted by Dave Jones View Post
    Thats actually exactly what Propagate Extents is for.
    cganiere likes this.
    Dave Jones's Avatar
    4,479
    11:04 PM
    well damn, learn something new everyday! I was going to say that I don't use PE very much. Now I know it's because I didn't know what it could do. We'll fix that situation
    tidalwave1 likes this.
    St. Louis, MO
    1,954
    12:04 AM
    A Scope Box will also help keep them aligned nicely. Place a Scope Box, and then assign it to your Grids.
    Moderator cellophane's Avatar
    August 9, 2011
    Louisville, KY
    6,050
    02:04 AM
    I just wish it wasn't such a PIA to use when views are cropped / dependent
    May 16, 2016
    104
    06:04 AM
    Yeah I already know about the propagate extents, but I can't get it to work right. Here's what I tried:
    Select all grids on the floor plan.
    Click propagate extents.
    Select the plans I want the extents propagated to.
    This does not work so far. The plans I want the extents propagated to are the same size, same crops, and some are just duplicate views.
    It seems strange, because when I select the grids on the floorplan and then tab over to another plan, they are selected there too, as they should be I guess. But how does Revit know from which plan I am doing this? Does it matter if the grids are 3D?
    I realized that if I duplicate a view with detailing AFTER I have already cleaned them up, that works well. But if I create a new view on a new level, I'm out of luck. And I also fear that if the Architect changes all the grids, I'll have to do this all over again.
    St. Louis, MO
    1,954
    12:04 AM
    Did you try a Scope Box?
    May 16, 2016
    104
    06:04 AM
    I just tried the scope box (for the first time ever)
    It does fix the grid bubbles, but it creates more problems in that it changes all the grids to be continuous through the whole plan. That doesn't work. See attached images.
    Again, I'm not a pro with the scope box. I just created it all around the entire plan, selected all the grids, and associated them to the scope box.
    Attached Thumbnails Attached Thumbnails Grid cleanup-scope-box.jpg   Grid cleanup-no-scpoe.jpg
  1. Gap or Space Between Grid Head and Grid Line
    By imsureakoto in forum Architecture and General Revit Questions
    Last Post: December 11th, 2017, 04:29 PM
  2. Revit Grid Lines With Grid # in Linetype
    By RenChan in forum Tutorials, Tips & Tricks
    Last Post: May 1st, 2017, 08:20 PM
  3. Site Grid vs Floor Plan Grid
    By SHAC01 in forum Architecture and General Revit Questions
    Last Post: March 27th, 2017, 09:03 AM
  4. Replies: 0
    Last Post: October 7th, 2016, 12:15 AM
  5. Customizing Grid Line Symbol and Grid Head Families
    By thaihoalu in forum Architecture and General Revit Questions
    Last Post: November 19th, 2014, 05:30 PM
