Page 1 of 3 123 LastLast
Results 1 to 10 of 24
Like Tree6Likes
Thread: Replace the actual value of a dimension
    October 16, 2016
    394
    07:29 AM
    Hello,
    I want to edit the value of a dimension. Instead of the actual value I want to display another number. How I can do this?
    Thank you in advance!
    October 16, 2016
    394
    07:29 AM
    Well... I just find it. Double click in the dimension text > Replace with text > Right click > Insert Unicode control Character.
    Forum Addict Robin Deurloo's Avatar
    July 7, 2011
    Rotterdam, Holland
    1,091
    07:29 AM
    #badrevit !!!!
    Andres Franco likes this.
    June 21, 2012
    Tours, France
    896
    07:29 AM
    Quote Originally Posted by Robin Deurloo View Post
    #badrevit !!!!
    agree, I've already knew that!, so I do prefer to not cheat on dimensions is quite a bit problematic and dangerous
    Member HansLammerts's Avatar
    April 22, 2011
    440
    07:29 AM
    Badass drafting skills. Beter have your ass covered ;-)
    June 21, 2012
    Tours, France
    896
    07:29 AM
    Quote Originally Posted by HansLammerts View Post
    Some years ago I used to work in an ATC, I have had a mayor client that was sued because one of the architects changed (Cheated) on the dimensions (in ACAD is quite easy), so one person measured the actual Building (a room actually) and that person found that the actual dimensions were wrong, so that person won the case and the Office should pay a large amount of money because the plans were fake
    April 22, 2011
    440
    07:29 AM
    I prefer "round", not edit. Especially for "..landscaping.."
    October 16, 2016
    394
    07:29 AM
    I need this 'cheat' in the details. When I create the detail for a door in a section view I don't have a lot of space to put the real height of the door so I make a section. After I need to edit the dimension for the ' empty passage' in order to correspond to the reality.
    HansLammerts likes this.
    June 21, 2012
    Tours, France
    896
    07:29 AM
    Quote Originally Posted by MARIA1993 View Post
    You can always change the "Scale factor" for your drawings/views to have enough space to put your dimensions, is better than cheating
    DaveP likes this.
    St. Louis, MO
    1,954
    12:29 AM
    Is the Section broken / split? This would cause the dimension ends to not be visible in the view?
    If so, as a workaround, you can use a Text Note, rotated 90 degrees with Arrows/leaders to show the door height. Not a very pure "BIM" solution.
    It would be better to place the dimension in a smaller scale view, then reference the enlarged section from it, and don't show the dimension in the enlarged view.
    Also, door heights are typically shown on a Door Schedule--so, the detail view could have a not saying "See Schedule for Height", or similar.
  1. Dimension strings not adding up to the total length dimension string (2017)
    By ledgewood33 in forum Architecture and General Revit Questions
    Last Post: March 26th, 2018, 03:24 PM
  2. Dimensions: Dimension Movement , Dimension Breaks
    By Usernumerouno in forum Architecture and General Revit Questions
    Last Post: October 7th, 2015, 08:15 PM
  3. Actual VS Nominal
    By Shields08 in forum Architecture and General Revit Questions
    Last Post: May 17th, 2013, 07:11 PM
  4. Need help. Actual project.
    By r7_human8y in forum Architecture and General Revit Questions
    Last Post: December 1st, 2011, 04:54 PM
  5. temporary dimension (dimension snap) remains large and off screen when zooming in
    By birdnehru in forum Architecture and General Revit Questions
    Last Post: October 27th, 2011, 06:25 PM
