Donate Now Goal amount for this year: 3000 USD, Received: 2290 USD (76%)
Page 3 of 3 FirstFirst 123
Results 21 to 24 of 24
Like Tree6Likes
Thread: Replace the actual value of a dimension
  1.    #21
    January 27, 2017
    North Dakota
    72
    08:07 PM
    Quote Originally Posted by MARIA1993 View Post
    You mean to have exactly the same door both in detail in floor plan?
    My problem is that for the floor plan I don't have this kind of door in 3D.
    I have the details only in 2D.
    I would make a new door family then that matches your 2D. I don't know how you make architectural parts but I make mechanical ones all the time when the manufacture doesn't have revit models.
  2.    #22
    October 16, 2016
    242
    01:07 AM
    Maria, the best option for this is to create a dimension style that makes the text be as small as possible and make it so it sits right on the line. You will have to add text yourself above the line. No cheating the actual dimension with unicode characters, it's like you're just using a family that creates dimensions.
    Hello and thank you for your answer!
    Sorry for the multiple questions that I have but I can try to understand why it is so wrong to do this...It is a drafting View in which I dont need to show the 2.10m door so I cut it in the middle and I need to have a dimension to indicate this 2.1m.
    If I add the dimension as you told me and after write manually the actual height of the door, the result will be the same, no? I will have again a dimension in which the text that I will write manually (the 2.10m) will be visible.
  3.    #23
    Member DavidLarson's Avatar
    July 10, 2015
    Boise, Idaho
    351
    07:07 PM
    IF... you must do it addint a period at the end of the edited number is the way to do it. It lets everybody know that it's an edited dimension without being obtrusive. I recently had to do that because the electrical engineer (picked by the client) refused to use Revit. His CAD drawings were less than ideal. For reasons out of my control I had to insert those CAD files into my RCP and dimension the light fixtures. I refuse to edit an engineer's drawing so the only way to make the dimensions viable was to edit the dimension. Since it wasn't going to be something that would break the project and we are so close to finishing this absurdly long project I said screw it - good enough to get a permit. I also know the chances of the lighting plan and what is actually built having any similarity will be around 1%.
    Is it good practice? Heck no. Does it get the permit? Yes. Does it make the client happy? Yes. Will it make any actual, real world difference? Not at all. It's a unique project so I know I can get away with it. But it makes me get Forrest Whitaker eye just thinking about it.
  4.    #24
    Moderator DaveP's Avatar
    January 10, 2011
    St Paul, MN
    2,482
    08:07 PM
    ..why is it so wrong to do this?
    There are (very rare) times when you absolutely need to "cheat" a dimension, but you really need to have an overwhelming need with no other options.
    The biggest problem with cheating a dimension - even in a Drafting View - is that once you've done it in one place, it becomes easier to do it in another. And another.
    And before long, it turns into "I don't have time to move that Wall, I'll just change the Dimension." And that destroys everyone's trust in the model.
    Once you find out the even one Dimension has been overwritten in a model, you start wondering if any other Dimensions are cheated as well.
    That said, we do have a Dimension Style that is rounded to the nearest 1/8" not cheated, just rounded. We have that Style set to red so we know which ones are not accurate.
    cganiere likes this.
  1. Dimension strings not adding up to the total length dimension string (2017)
    By ledgewood33 in forum Architecture and General Revit Questions
    Last Post: March 26th, 2018, 03:24 PM
  2. Dimensions: Dimension Movement , Dimension Breaks
    By Usernumerouno in forum Architecture and General Revit Questions
    Last Post: October 7th, 2015, 08:15 PM
  3. Actual VS Nominal
    By Shields08 in forum Architecture and General Revit Questions
    Last Post: May 17th, 2013, 07:11 PM
  4. Need help. Actual project.
    By r7_human8y in forum Architecture and General Revit Questions
    Last Post: December 1st, 2011, 04:54 PM
  5. temporary dimension (dimension snap) remains large and off screen when zooming in
    By birdnehru in forum Architecture and General Revit Questions
    Last Post: October 27th, 2011, 06:25 PM
